<back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 11-27-2001, 06:18 PM
littlegreenman  is offline
Posts: 2,626  -  iTrader: (4)
Another chord question - help!
Ok, here is the chord
From Low E to High E *F#, A, D, A, C, G
The song is in the Key of G I believe, (not fully sure)
Anyway, my best guess is the chord is a Amin7sus4/F#
Sound close to anyone? *
hehehe, thanx for any help I can get
Jeremy
Old 11-27-2001, 09:06 PM
dwswift  is offline
Posts: 165  -  iTrader: (0)
Jeremy,
It's a D7sus4 chord but you have the third stuck on the bottom causing a real strong dissonance. *A dominant chord doesn't have the 11th tension available as a chord tone theortically but do whatever sounds good to you It's either a D7/F# with the 11th tension on top or a D7sus4 and you can skip that pesky F#
Try moving the F# to G? *Sounds better to me. Definately a dominant chord to my ears though.
Hope I helped a bit...
Old 11-27-2001, 11:56 PM
JESTER700  is offline
Posts: 2,234  -  iTrader: (0)
What does it resolve to? *That should tell the tale..
Old 11-28-2001, 05:42 PM
ericbrowning  is offline
Posts: 84  -  iTrader: (0)
F# resolves to G, in most cases; at least in Western music that is. *Listen to a little Mahavishnu and everything goes out of wack!
Old 11-28-2001, 06:57 PM
dwswift  is offline
F# usually does lead to G, but with the G on top, it wants to resolve down to F# because that would be a 4-3 suspension of the V7 chord.
