Go Back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 07-25-2006, 08:45 AM
dannypuk dannypuk is offline
Posts: 49  -  iTrader: (3)
building the church help
hey all, am currently learning the tapping part to building the church and am having some trouble.
the intro is ok as i can use my left palm to mute excess noise but im getting alot of string buzzing which i cant think of how to mute, the left hand is to busy moving around (in the solo section tapping) to even attempt to mute, and the right hand is busy and also cant mute, so how the hell do you get rid of the string excess noise and get it to sound cleaner?, i would have thought muting the strings at the headstock end with a cloth would work, and it does, but i know that he doesnt use one. i tried rolling off the volume on the guitar to get rid of some but its still not good enough. i was thinking that pehaps steve uses a gate (supresses any noise lower than a certain decibel level) and im sure this also work, but not sure is uses this method.
anyone solved this problem or know how to mute the strings when both hands are moving across the neck?
any help would...help
dan
Old 07-25-2006, 09:58 AM
Pleuvra Pleuvra is offline
Posts: 70  -  iTrader: (0)
Re: building the church help
I had this problem.
I just practiced until my fingers could hammer the notes harder, so they would be louder than the noise.
I also tried muting in various ways (LH and RH) and that helped, so does using the neck pickup, and less gain.
I have a problem shifting the left hand in the solo bit, though, it makes string noise (just during the bits where your right hand stays where it is) , and I can't figure a way around it.....help me, too!
Old 07-30-2006, 12:15 PM
ok man, for those interested ive figured out how its done
Ok its quite subtle but it IS the left hand that mutes the strings to get rid of the unwanted noise, its quite difficult to do and makes it more difficult to tap with the left hand but it works.
Place the left hand with the left side of the palm muting most of the stings (about 6th-3rd/2nd), it does not mute all the strings as this completly screws up the flexibility but it dampens most of the strings that cause the terrible noise, the 3rd finger on the left hand rests on the side of the neck (side facing floor) and the little finger rests just behind that, the thumb is used to support the rest of that hand.
With this position it mutes virtually all of the strings and sound so much cleaner, its a little more difficult at first but practicing the motions and keeping a strict hand position pays off big time. the final hardest is the movment during the solo section, and it is difficult but as long as you practice slow the position changes, and importantly the hand position during the changes, making sure the left hand is in the position i described. all unwanted noise is reduced
good luck man as its a corker when it gets flowing cleanly.
once the hand position is sorted and its clean slow, its just a case of practicing it again and again
dan
Hal Leonard Blues Solos for Guitar Book/CD
As low as $11
at 9 sellers
Hal Leonard Robin Trower Guitar Signature Licks (Book/CD)
As low as $12
at 9 sellers
Members with more than 50 posts don't see this bar
Hal Leonard Las Canciones De Joan Sebastian Piano, Vocal, Guitar Songbook
As low as $9
at 12 sellers
Everly B-52 Rockers Alloy Extra Light Electric Guitar Strings
As low as $6
at 4 sellers
Pigtronix PolySaturator Distortion Guitar Effects Pedal
As low as $147
at 9 sellers
Kaces Boutique Polyfoam Electric Guitar Case
As low as $70
at 6 sellers
Electro-Harmonix Nano Pocket Metal Muff Distortion Guitar Effects Pedal
As low as $55
at 9 sellers
Daisy Rock Rebel Rockit Heart Left-Handed Electric Guitar Black Pearl
As low as $297
at 3 sellers
Dean Markley 2557 DT Blue Steel Drop Tune Electric Guitar Strings
As low as $6
at 8 sellers
EMG ACS Acoustic Active Soundhole Pickup System
As low as $130
at 6 sellers
Martin LX1E Little Martin Acoustic-Electric Guitar
As low as $33
at 11 sellers
Parker P-36 Electric Guitar Blonde
As low as $749
at 3 sellers
Taylor Koa Series DN-K Acoustic Guitar Natural
As low as $2085
at 4 sellers
Shadow Quick Mount Classical Guitar Pickup and 12' Cable
As low as $135
at 3 sellers
neck pickup, palm muting
close
Sign up for free and join one of the largest communities of Jem guitar lovers!
Our members will be glad to help you with anything you need!
Join over 30,000 JemSite members!
Email
Email Confirm Email
Username
Password Confirm Password
I agree to the website rules
