Players, People, Music and Tours
Guitar Lessons & Music Theory
Do bends have to be dead in tune?
Post any type of guitar or music lessons, theory and other learning methods.
04-29-2007, 06:07 AM
Rekuss
Posts: 452 - iTrader: (
Hey,
Well I'm having some problems with my bends at the moment, I'm finding it hard to get them exactly in tune. So here's my question, is it ok if bends are slight flat/sharp. If so How many cents, roughly?
One last question, has anyone got any good ideas for perfecting bends?
Many Thanks
Reece
11:06 AM
Rekuss
Visit Rekuss's homepage!
Find all posts by Rekuss
04-29-2007, 06:20 AM
richard1973
Posts: 957 - iTrader: (
Reviews: 10
Re: Do bends have to be dead in tune?
Is this for your own song/tune or a cover? if its a cover i guess you best get it spot on, if not then it's utpo you, as long as it's in key. You can do bends for half steps or full, upto you (unless its a cover).
my tip is i prefer to bend with my 3rd figner (wedding one) then you can use index and middle for support if your struggling to bend it.
richard1973
Visit richard1973's homepage!
Find all posts by richard1973
04-29-2007, 12:31 PM
OLIE_ROCKS_THE_80'S
Posts: 2,770 - iTrader: (
Reviews: 10
Rekuss
Hey,
Many Thanks
Reece
Practice, Practice Practice!!! you should always make your bends perfect!!!
I can always tell an apprentice guitarist from a mature player in the way they bend, so No in my opinion is not right to bend out of tune!
OLIE_ROCKS_THE_80'S
Find all posts by OLIE_ROCKS_THE_80'S
04-29-2007, 01:10 PM
GilkyBear
Posts: 4,110 - iTrader: (
Here's the thing, before you do the bend, decide in your mind where you want it to go. If you want it to go up a whole step for example, then it should. If it doesn't, then of course you need to keep working on it. Your fingers should be doing what you want them to, or you need to keep working on it.
GilkyBear
Find all posts by GilkyBear
04-29-2007, 01:15 PM
andy7jem
Posts: 6,504 - iTrader: (
They don't have to be dead but they do have to be in tune
andy7jem
Find all posts by andy7jem
04-29-2007, 01:18 PM
GilkyBear
andy7jem
GilkyBear
04-29-2007, 04:47 PM
Rekuss
andy7jem
Yeah, that's what I'm asking, is it ok if they're a few cents flat/sharp?
Thanks a lot for your responses, I've just changed the way I practice, I used to be all technique but it didn't really help. I wasn't 'shredding', I was boring etc etc. Now I've got goals and study pieces I'm working through and everything is much more enjoyable. Also, I thought I needed time allotments for each area of practice otherwise I wouldn't be getting anywhere. But by throwing away the pressure of working with the clock everything is a lot more laid back.
Rekuss
04-29-2007, 07:21 PM
andy7jem
You could try what Satch has mentioned. Just spend a bit of time hitting a fretted note, then hit a note below and bend to it so your ears know the pitch you are aiming for. Repeat over and over all over the neck and different size bends!
andy7jem
04-30-2007, 11:05 AM
Rekuss
Yeah, I kinda do that with a chromatic tuner just to make sure i'm in tune.
Thanks a lot for the responses!
Reece
Rekuss
05-01-2007, 12:33 PM
shogun
Posts: 1,525 - iTrader: (
Rekuss
Hey,
Many Thanks
Reece
it is your ear that you are having trouble with.. you need to work at it and do ear training until you can hear when a bend is in or out of tune.. if you are bending a halfstep, fret the note halfstep above, then bend to it.. same thing for a whole step.. just use the fretted note as a reference.
shogun
Visit shogun's homepage!
Find all posts by shogun
05-02-2007, 04:24 AM
Tubarão Guitars
Posts: 3,963 - iTrader: (
bending and vibrato walks together to me, so bending without vibrato is boring and slight always out of tune, IMO.
educated ears can make educated fingers (by all means LOL
Tubarão Guitars
Visit Tubarão Guitars's homepage!
Find all posts by Tubarão Guitars
05-02-2007, 04:31 AM
The Euphor
Posts: 2,948 - iTrader: (
Practice. Play your target note, then play a note two frets down and bend up to the target note. Doing this all over the neck may help you getting used to the ever changing tension of the strings from fret 1 to the top fret.
Takes time to get it right, but it is well worth the hassle. And most likely, your ears will improve while you practice your bends. That's a good thing.
The Euphor
Find all posts by The Euphor
05-02-2007, 04:44 AM
JJEMMER777
Posts: 8,374 - iTrader: (
The Euphor
Practice.
Yep - key word!!
And as Jimmy Savage would say *listen*
JJEMMER777
Find all posts by JJEMMER777
05-02-2007, 07:01 AM
shannon
Posts: 29 - iTrader: (
I think your bends should be in tune.Whenever I hear guitarists bending either sharp or flat I cringe.If you intend on bending up a whole step,say for example A to B,make sure it is B that you bend to,not B flat or C.
shannon
Find all posts by shannon
05-02-2007, 04:12 PM
Rekuss
Thank you for all your tips.
shannon
Yeah, but bends aren't that bad, they are just a few cents sharp/flat.
Rekuss
how to tune lo-trs
where can i get big bends nut sauce in Australia
how to tune jem 555
when using tremolo bar tune is bad
WHAT KIND OF GUGE DO I NEED TO TUNE TO DROP A?
WHY WILL MY JS NOT STAY IN TUNE?!?!
Smitty
09:36 AM
Can't... Tune... Floyd... Rose...
Kid Vicious
Tech: Setup, Repairs and Mods
03:28 PM
Unison bends
thc303
01:04 PM
Lo Pro on my PGM300 - keeping in tune
metalgandalf
10:46 AM
New JS Model Info - JS-2000CG
mike777
103
04-05-2002
06:50 PM
02:35 AM
