Go Back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 06-16-2001, 10:47 PM
Two hands31 Two hands31 is offline
Posts: 8,427  -  iTrader: (0)
Fretboard and Tapping
I have two questions:
1) *How much does a scalloped fretboard affect your playing/the feel of the guitar/technique required?
2) *How can I improve my tapping technique?
Old 06-17-2001, 01:45 AM
bachle7 bachle7 is offline
Posts: 365  -  iTrader: (0)
1. *A LOT! *I found that I could bend notes to the sky! *Of course, I also found that I would make notes go sharp if I pressed too hard on the strings. *It was a double-edged sword for me.
2. *Practice, especially with yout guitar unplugged; that will make you do it more precisely because you will only be able to hear it if you do it right.
Old 06-17-2001, 04:40 PM
jem7vwh jem7vwh is offline
Posts: 2,699  -  iTrader: (3)
practice your tapping a lot. *Don't worry about speed until each tapped note is as clear as a picked one.
Also, try using all your fingers
tap with your index, middle, ring and pinky
Old 06-17-2001, 07:54 PM
YaYoGakk YaYoGakk is offline
Posts: 1,722  -  iTrader: (0)
I scalloped the fretboard on my yam*ha but I'm finding it hard to get a feel for it as the necks on $200 guitars generally suck anyway. Like bachle7 said, too much pressure and your notes end up sharp, I never really found this to be a big problem because i have a pretty light touch.
* I haven't been doing as much tapping as i used too but like everyone's saying start slow and make sure each can be hear each note clearly before bumping the speed up. You want to be able to play it well slowly before increasing your speed.
Like they say walk before you run.
Alden
PS- thats $200 brand new :biggrin:
Old 06-18-2001, 10:54 AM
Mirrored CAT Mirrored CAT is offline
Posts: 174  -  iTrader: (0)
I wouldn't practice with the guitar unplugged. In fact, I would turn the sound up. There are lots of unwanted sounds that you want to be able to mute when you're learning a new technique. If you're practicing it with your guitar unplugged, it will seem to you that your technique is perfect. But if you raise your volume you'll be able to improve on the accuracy and also in muting all the unwanted strings noises that you cannot hear unplugged.
Hal Leonard Music Theory for Guitar Book
As low as $4
at 7 sellers
Hal Leonard Rancid And Out Come the Wolves Guitar Tab Songbook
As low as $12
at 7 sellers
Members with more than 50 posts don't see this bar
Hal Leonard Beginning Blues Guitar (Book/CD)
As low as $5
at 9 sellers
Rocktron Zombie Rectified Distortion Pedal
As low as $0
at 9 sellers
Takamine GB-7C Acoustic-Electric Guitar
As low as $1299
at 13 sellers
Martin FX740 Phosphor Bronze Acoustic Light Guitar Strings
As low as $5
at 4 sellers
Rotosound Superia Ball End Normal Tension Classical Guitar Strings
As low as $6
at 5 sellers
Dean Markley 2065A PhosBronze CL Acoustic Guitar Strings
As low as $6
at 7 sellers
Dean Acoustic Bass Hardshell Case
As low as $108
at 8 sellers
DNA Analogic VT-1 Virtual Tube Overdrive Pedal
As low as $240
at 6 sellers
Ibanez JS1200 Joe Satriani Signature Guitar Candy Apple
As low as $1399
at 11 sellers
Visual Sound V2 Series V2DT Double Trouble Dual Overdrive Guitar Effects Pedal
As low as $150
at 10 sellers
THD Univalve Rackmounted Guitar Amp Head Black
As low as $1069
at 3 sellers
Danelectro Spring King Spring Reverb
As low as $0
at 7 sellers
scalloped fretboard
close
Sign up for free and join one of the largest communities of Jem guitar lovers!
Our members will be glad to help you with anything you need!
Join over 30,000 JemSite members!
Email
Email Confirm Email
Username
Password Confirm Password
I agree to the website rules
