<back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 10-18-2006, 08:08 AM
klp2332  is offline
Posts: 280  -  iTrader: (1)
Guitar Transposition
Hi,
As you all I know, my theory sucks.
Does anyone have any tutorials on transposition. I cant seem to find any.
Well actually iam trying to transpose this very simple( http://www.911tabs.com/link/?330373 ) from what i believe is F# to F. It would be best if anyone could directly help me with transposing the song.
Thanks
Old 10-18-2006, 08:18 AM
ChopTart  is offline
Posts: 1,390  -  iTrader: (1)
Re: Guitar Transposition
I'm not sure that song is in F# - it looks to me like the resolution of the chords is E or possibly A (subdominant?). Also, the key F# would have A# in it, not A natural. Are you sure that's the right link? maybe you meant to link to another song?
Either way, transposing keys isn't so bad - you just take the notes and their respective degrees, then you use those same degrees in a the desired scale. For instance, a I, IV, V in F# would be F#, B, C#. If you wanted to change this to F, you would take the same degrees of the scale, but just use a new key signature - so using F (scale: F, G, A, Bb, C, D, E), the NEW I, IV, V would be F, Bb, C, dig?
Last edited by ChopTart; 10-18-2006 at 08:19 AM. Reason: Meant to say "subdominant", not "dominant"
Old 10-18-2006, 09:00 AM
klp2332  is offline
Oh thanks, I think i understand a little more.
Your right, it is in E. Ok so if its from E -> F then.
Everything will become a semi-tone higher?
Old 10-18-2006, 07:46 PM
ChopTart  is offline
Pretty much - you'll be playing with the new key signature, but the same note degrees. In this case, everything is moved up a minor second (semitone).
So instead of four sharps (F, C, G, D), you'll be using just Bb as an accidental. The chord E will be replaced with an F chord, A (the fifth degree aka dominant of the original E key) would be replaced with the new dominant of the new key, Bb. B, the sixth degree of E, would be replaced with the sixth degree of the key of F, which is a C.
I assumed you wanted to change it from E maj to F maj.
Hope this helps, I'm not great at theory, but I believe that's all correct. Any more questions - ask away
Old 10-19-2006, 07:08 AM
klp2332  is offline
Ahh i just realized i posted the wrong link. But same song.
Heres a better one.
http://www.ultimate-guitar.com/tabs/...r_ver3_tab.htm
Need help transposing this. I think i got the gist of it so ill try transposing my self too.
But what about the solo? Please Help
Old 10-19-2006, 07:14 AM
klp2332  is offline
If there was a D# in the original key. Does it change to E or does it stay at D? Because the accidently is removed then it changes 1 semitone up.
Funny guitar article Dino Other 6-string Guitars (non-Ibanez brand) 40 05-11-2007 09:24 PM
Guitar Player, Guitar World Back Issues (Satch & Vai) jippy Classified Ads: Guitars and Gear 2 12-24-2005 01:40 AM
guitar man with nothing but bad attitude Joshka Other 7-string Guitars 0 02-25-2004 10:58 AM
Any classical guitar gurus out there? looking for appraisal Willin Other 6-string Guitars (non-Ibanez brand) 4 09-17-2002 07:55 PM
tonight's guitar tech and mod work - my RG520Q is a tone MON AJ Love Tech: Setup, Repairs and Mods 4 09-04-2001 08:55 PM
