Players, People, Music and Tours
Guitar Lessons & Music Theory
help...good guitarists please read this
Post any type of guitar or music lessons, theory and other learning methods.
02-11-2003, 06:15 PM
Sid Vai
Posts: 63 - iTrader: (
ok the other day i saw a guy play something very heavy metally. it sounded like he was tapping but he was using the pick normally. it had something to do with the first two strings. what is it and how do execute it???? he didnt teach me how to do it
he did teach me something. something really cool. he perfomed a bend like. on the third string. at the seventh fret upwards. then with his right hand's index finger he harmonicked that same string arouynd the 17th fretit sounded like the note went falt or something. ...i hope i explaiend it clearly.
but for now please help on the first question....anyone?????
Sid Vai
Find all posts by Sid Vai
02-11-2003, 06:28 PM
EKG
Posts: 2,280 - iTrader: (
Your first question, I am not quite understanding...
The second part...EVH does a lot of...check out his solo stuff on VH videos. Basically, "bridging" the string at a specified fret then tapping harmonics ;-)
EKG
Visit EKG's homepage!
Find all posts by EKG
02-11-2003, 06:52 PM
Posts: 19,352 - iTrader: (
He was probably using the open string as a pedal point and alternating it in with what he was fretting, sorta sounds like tapping.
02-11-2003, 11:13 PM
Sid Vai
Eddie Kolesar
ok i dont know how to describe it...if i knew i owuld just do it on my guitar.
ok, he was picking the strings. he uses the first two strings and it sounds like a lot of pull off and alternating the ring finger from second string to first string. it sounds like tapping and i want to know how to do this...please help...anything that sounds similar will do.
Sid Vai
02-11-2003, 11:22 PM
Oh, 2 different strings. That's another Satchism. It still involves the open strings and now you're just fretting one fret per string. "Sweep" [if you can call it that] your pick across the 2 open strings then in the same tempo hammer on the 2 notes [one at a time of course, not together], repeat
02-11-2003, 11:26 PM
You can sweep in either direction and hammer on in the same or opposite direction, plenty of variety here.
02-11-2003, 11:27 PM
BrianH
Posts: 599 - iTrader: (
is he possibly talking about trilling the string with the edge of a pick? Satch does that alot too. Kinda sounds like tapping(although hyper speed).
BrianH
Find all posts by BrianH
02-12-2003, 12:28 AM
Sid Vai
yes it sounds like tapping but he does it with the pick, like normal playing. it should sound like tapping
Sid Vai
02-12-2003, 05:59 PM
Swirly
Posts: 430 - iTrader: (
I was looking at somthing the other day and someon mentioned you could finger tap with a pick instead of the tapping finger. Is that how you mean? ie normall tapping, but instead of tapping the fret with you finger use a pick. Ive tried but cant seem to get this affect right...how is it done correctly?
Swirly
Find all posts by Swirly
02-12-2003, 06:42 PM
Sid Vai
no, hes playing normally, like right hand over pikcups, except it sounds like tapping. im going throug all this trouble bc the guy doesnt want to teach me how he does it
Sid Vai
02-12-2003, 06:57 PM
02-13-2003, 12:35 PM
Lenny
Posts: 19 - iTrader: (
I think this is what you mean:
|-----5-----------8---------5-------------------|
|--------5--0--5----5-0-5----5-0-5-etc-------|
Use hammer on's and pulloffs on the B string.
Large intervals like this may create the illusion of tapping.
Lenny
Visit Lenny's homepage!
Find all posts by Lenny
02-13-2003, 03:03 PM
BrianH
I think Rich is explaining something like this...
---0-----5---0------8-------
-0----5---------0------8----
This could be done alot of ways, not just with double stops. you hammer on from the open string to the fretted notes. Atleast this is what I think Rich is talking about.
BrianH
02-13-2003, 03:19 PM
I suck at tabbing, but here goes
-0---7-0---7-0---7-0
--0-5---0-5---0-5---0
That's using an upsweep on the E and B strings and hamerring on the B first then E. Like I said, all kinds of combinations available here.
02-13-2003, 03:25 PM
How about one where the open string doesn't match a hammer
-0---9-0---9-0---9-0
--0-7---0-7---0-7---0
crystal planet
heavy metal
john petrucci
sweep picking
van halen
how to tell the good pick-ups from the bad
What program do I use to read power tabs
what makes a good middle pickup
guitarists who thought they sucked
What amp sounds good with the Jemini pedal?
12:34 AM
