<back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 02-02-2006, 02:15 AM
Sam101  is offline
Posts: 69  -  iTrader: (0)
I jsut need more explanation for theory modes, technique....
I need more techniques and I would like some good examples of how I can use the modes to put together a good solo and rythem....... I'd thank you a million for it.....
Old 02-02-2006, 02:34 AM
vette6600  is offline
Posts: 881  -  iTrader: (0)
Re: I jsut need more explanation for theory modes, technique....
find a song you like, find out what key it is in, and see what ideas the guitarist is using.
personally i think a good teacher is necessary to get your theory/technique up to a level where you are fairly confident, and from there you can figure out a lot on your own (i have no idea what level you are at, so this may not be helpful)
Old 02-02-2006, 02:42 AM
Sam101  is offline
well I've just started learning theory I've got modes down....and I've just been kind of lost on how I can like improvise through the modes to come up with a good lead....but yeah that song idea is what Ive been thinking about and sounds like a solid idea.....would you have any songs in mind that can help?
Old 02-02-2006, 02:57 AM
mi2tom  is offline
Posts: 7,522  -  iTrader: (4)
about modes .... I think you need to play the song which the guitarist is playing for example if you want to play lydian, play vai's music like kim pee du wee or boston rain melody, if phrgyian try playing some of al di meola's
Old 02-02-2006, 04:25 AM
gu1tar  is offline
Posts: 858  -  iTrader: (0)
1) Buy a Fender G-DEC (if you can - they are about $265) and you can play along with the built in jam tracks and it tells you what key you are in or if you like the rhythm, you can change the rhythm to another key. I think it's one of the best ways to practice the modes and your improvisation.
2) If you can't afford that, you can try to find some jam tracks other places. There are some guitar books these days that come with jam tracks.
Old 02-02-2006, 11:14 AM
Grev  is offline
Posts: 189  -  iTrader: (0)
Getting started is always the hardest, I'm not too sure what mindset to tell you to go in to get started, but I'm trying to work on it, maybe some of the others can tell you more on that for the time being.
Old 02-02-2006, 11:31 PM
first off, do you know your minor pentatonic scale? i'd check out AC DC. i could NEVER bring myself to listen to that band, but i think there is a lot to learn because there songs are very simple, but well done.
do you have a teacher?
Old 02-03-2006, 01:18 AM
sirnothingness  is offline
Posts: 14  -  iTrader: (0)
Not to sound critical, but you say you have modes down, but don't know what to do with them. You're making the same mistake many guitarists do. Take it easy and don't expect to know modes overnight. I'd personally start with one and learn it. Then work with it for awhile until you actually hear the feel of the mode. You probably have been told to simply play a major scale but start on a different root. The problem with that is you'll end up soundiing like the original key and wont get the feel of the mode you're after. Find out what makes a particular mode different from it's major (or minor) counterpart. For instance, lydian has a raised 4th. That gives it a much different sound from a major. Play c major, then learn C Lydian instead of playing C major and starting on the F. Work with it for awhile. There's no need to get all modes down right away. You may very possibly never play some of them anyway.
Get the major scale, minor scale down and you've got two modes right there. But don't think that you have them down until you've played them and can recognize them from eachother regardless of which note you start on.
Old 02-03-2006, 01:28 AM
Sam101  is offline
ooh alright I gotcha now
Lesson 13: Tapping overview - right hand technique jem7vwh Guitar Lessons & Music Theory 19 01-11-2005 11:00 PM
