<back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 11-20-2001, 07:46 PM
nickelsack  is offline
Posts: 8  -  iTrader: (0)
juice tapping - how does mr. vai get it so clean
Alright kids when vai goes on his little tapping run at about 2:13 in the song juice how does he get it to sound so nice! *I can go through it and hit the notes but the problem is all the loose string make it sound like crap. Any tips on how to catch those loose strings, other than being vai.
Old 11-21-2001, 02:57 AM
jem7vwh  is offline
Posts: 1,583  -  iTrader: (3)
Reviews: 4
juice tapping
a few tips:
Hand muting is important. *Both with your fret hand and tapping hand, you should be constantly keeping the other strings silent as you work your way from the G to the B and finally the e string.
Lots of gain and compression. *Vai was using a Bogner Ecstacy at the time. *Bogners are known for their gain.
Practice. *I posted a lesson on that tapping a while ago here in the Lessons area. *Look it up and practice along with the .wav file included there. It's been a few months since that was posted. *I was about 85% fluent then. *I can play it near perfect now. *
Old 11-21-2001, 02:18 PM
Devo  is offline
Posts: 1,483  -  iTrader: (20)
juice tapping
Depending on your tapping style, you could try to mute the open stings with your right hand as well, I generally find it easier to muste the bass strings with my index or palm on right and the higher strings with the index on left.
then everyone does it different. play it slow and work out where you can mute the strings with which fingers most comfortably and make the mutes part of playing the tune.
Old 11-27-2001, 05:05 AM
Courjan  is offline
Posts: 171  -  iTrader: (0)
juice tapping
*This may sound a little cliche, but use a metronome and start at very slow tempo. I had had problems with muting even at that speed when I was learning that part.
* When the notes ring clean enough gradually increase tempo and make your way to the original.
Old 11-27-2001, 12:15 PM
juice tapping
I slowed it down and practiced it and it is getting alot clearer, but it is hard to decide just how to go about muting it. *Are you using your right left or a combination of the 2.
Old 11-27-2001, 02:17 PM
Devo  is offline
juice tapping
both
bogner ecstacy, higher strings
