<back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 01-04-2002, 07:14 PM
jem7vwh  is offline
Posts: 1,583  -  iTrader: (3)
Reviews: 4
Lesson 13: Tapping overview - right hand technique
Tapping Overview
What is tapping? For the purposes of this tutorial, tapping is just a nice generic name for any kind of two handed articulation technique.
What's the differences? Well, there's standard tapping (popularized by Edward Van Halen), bi-dextral tapping (practiced by Vai, Michael Angelo, and countless other virtuosos) and other variants.
Beginning Tapping:
There are two reasons you'd want to use tapping. First is a case where you want to use a wide interval that your fretting hand can't reach. The second case is that you want to articulate more notes than you have fingers on your frethand. It also looks impressive
If you've never used right hand technique before, you're going to be reminded of how your fingers felt when you first started playing. That is, steel strings hurt your fingers at first. It's important to try and build up your skills before delving into "Hot for Teacher".
What you want to try to do is press down on the fret indicated with your tapping finger with enough force to sound the note. You don't have to break your hand, but try to make it as articulate as possible. If you don't do it right slow, it's going to sound like mush when it's fast. Keep in mind that tapping is like legato, most of the sound created comes after you pull off. Try this exercise:
note preceeded by a "t" are to be tapped.
Code:
e---------
B-t9-p2-h5
G---------
D---------
A---------
E---------
focus on clarity and smoothness first. Like any other technique, the speed will be easier to learn if you can already do it slowly.
This is as good a time as any to discuss which fingers you decide to tap with. The greats all have preferences. EVH likes to hold his pick with his middle finger and thumb while he taps with his index finger. Vai is more often seen holding the pick in a standard (index & thumb) grip and tapping with his middle and ring fingers. It's really up to you. When I'm instructing, I usually advise folks to tap with their middle finger, it keeps your hand holding the pick and ready to pick notes along with the taps, or to sweep pick. There are always exceptions though.
Understanding the Theory Behind Tapping:
I could just as well have called this section ("How do I know which notes to tap?"). That's probably the most-often asked question I get regarding two-hand technique. The easy answer is; do whatever you want. The explanation takes more time. Basically, two-handed technique should just be an extension of your regular soloing. So, when deciding what to tap, just think about what notes you play when you're fretting those notes normally. This is a good way to get started.
For example, say you're soloing in C Ionian (C Major). How would you solo in the 5th position or in the 13th position. Maybe it'd be something like this?
Code:
e------------5h8--------13-15
B--------5h8------13-15------
G-----5v---------------------
D-5h7------------------------
A----------------------------
E----------------------------
Notice all of those notes are directly from C Major.
Now, to create a basic tapping run, just combine those two ideas, shown here:
Code:
e---------------------------------5h8-t13-p8-p5-t15-p8-p5
B---------5h8-t13-p8-p5-t15-p8-p5------------------------
G-----5h7------------------------------------------------
D-5h7----------------------------------------------------
A--------------------------------------------------------
E--------------------------------------------------------
The next step is to think about what you want to do with your tapping. You can change the feel of a song with both your choice of notes and the way you play them. Use wide intervals to give the solo a feeling of unraveling, like the melody is pulling itself apart, use closer intervals to give the solo a cascading feel (like a piano roll).
You can also use your tapping to give the solo a different tonality.
Here, the left hand plays from C Ionian, while the tapped notes are taken from the Dorian mode, this will give it another different feel.
Code:
e---------------------------------5h8-t13-p8-p5-t18-p8-p5
B---------5h8-t14-p8-p5-t15-p8-p5------------------------
Beyond Basics:
There's obviously more to right hand technique than fretting notes the way you would with your left hand. Other uses are as follows:
  • tapped slides
  • tapped harmonics (as in Van Halen's "Women in Love")
  • backward tapping (a la Rasberry Jam Delta V)
  • pick tapping (guess what this is)
Tapped Slides are just another one of the techniques found on early Van Halen albums. It's as easy to do as it sounds. Instead of just tapping stright down onto a fret, tap and slide your finger up the board. You'll hear a sliding sound as you pull off.
Tapped harmonics are slightly different. In every previous case, you've been pressing down fairly hard to articulate the notes. Tapped harmonics require just as much pressure as natural harmonics. What you do here is fret a note with your left hand, and tap on the fret that is 12 frets above it. In this case you're actually going to try and tap on top of the steel fret, not over the wood. You should hear a harmonic that sounds like a *ping*.
Backward tapping is done when you use your picking hand to fret notes higher than your fretting hand. Then you use your fretting hand to tap notes farther up the board. Joe Satriani does this to great effect on Rasberry Jam Delta V.
Pick Tapping is simply tapping with the pick :biggrin:
Other varieties and complexeties are everywhere, but this should serve as a good intro.
Songs to work on:
beginner:
  • Van Halen "Panama" (standard tapping)
  • Van Halen "Women in Love" (tapped harmonics)
  • Steve Vai "Liberty" (standard tapping)
intermediate:
  • Van Halen "Mean Street" (bi-dextral tapping)
  • Eric Johnson "Venus Isle" (tapped harmonics)
  • Van Halen "Hot for Teacher" (standard tapping)
difficult:
  • Steve Vai "Juice"
  • Van Halen "Eruption" (simple stuff, but you'll need endurance)
  • DLR "Big Trouble"
Old 01-04-2002, 10:07 PM
Given to Fly  is offline
Posts: 450  -  iTrader: (0)
Thanks for posting this little lesson. I have never really thought about my tapping technique, but now see that it could be much better. I look forward to working on it.
Old 01-05-2002, 01:34 AM
Kevan  is offline
deleted username
Posts: 1,429  -  iTrader: (0)
Now we're cookin' with gas!
I was chatting with Chris about this the last few nights. *I LOVE to tap! *Unfortunately, I don't posess the theory knowledge he does, so I do the "seat of my pants" type of tapping. *I'll offer some simple stuff, with no major theory aspects; only the patterns and runs that I've found work great.
I don't hold my pick like any of the descriptions above. *I had a little accident a few years back, and cut my right-hand middle finger in half (I failed the Idiot Test and tried to catch a falling X-Acto knife with a brand new blade). *Luckily, the doctors put my finger back together, but the nerve damage was irreversible. *This makes holding my pick, and doing other things with that finger, quite challenging. *I don't use my right-hand middle finger for tapping. *Instead I use it to "clench" the pick. *I've gotten quite fast at swapping it back and forth between tapping and strumming/picking. *
Also, I really don't get into doing the Joe Thing and using the pick to tap, but you can try it out. *Maybe that works good for you, and it's definitely an interesting effect.
I'll also shoot some quick movies of each example this weekend, and they'll be available thru email.
DO NOT expect Michael Angelo or Jennifer Batten-type stuff. *:-)
Most of these are VERY simple, but can be worked up into nice and tasty compliacted runs. *For now, and since I'm not Shane Regal, I'll leave them as decending runs.
Someone had asked about the tapping in "Jump". *Here's one of the runs EVH does:
[font=courier]
e--12t-8p-7p-5-(2x)------------------------------------------------------------
B-----------------12t-8p-7p-5-(2x)---------------------------------------------
G--------------------------------11t-7p-6p-5-(2x)------------------------------
D-----------------------------------------------11t-7p-6p-5-(2x)---------------
A--------------------------------------------------------------12t-7p-6p-5~~~~-
E------------------------------------------------------------------------------[/font]
It's a fairly simple decending run, ending with a little vibrato on the D (5th fret, A-string). *If you remember the video for the song, you know how important it is to look down into the camera and do the "woooo!" at the end of it. *:-) *
Here's one that's GREAT for practicing and warming up, with a lemon twist. *The left hand does simple chromatic pulloffs (14-13-12) all the way down the neck. *Ahhh- but the right hand taps out the "important" notes of the scale you want to slip in there. *I think of it as a "backwards tap" because your right hand is doing the actual work. *:-) *The other cool thing about this one is that you can plop it in with a bunch of different sounds; the chromatic "back" sounds pretty cool.
[font=courier]
e--17t-14p-13p-12-(2x)-----------------------------------
B-------------------17t-14p-13p-12-(2x)------------------
G------------------------------------17t-14p-13p-12-(2x)-
D--------------------------------------------------------
(continued)
e----------------------------------------------------
B----------------------------------------------------
G----------------------------------------------------
D--17t-14p-13p-12-(2x)-------------------------------
A-------------------17t-14p-13p-12-(2x)--------------
E------------------------------------17t-14p-13p-12--[/font]
In the example above, I just used the 'back end' of a simple pentatonic scale. *Both left and right hand travel a linear path. *Feel free to experiment, with your right hand, with other 'back ends' and 'front ends' of your favorite scales.
I'll chop this one up later and post some cool variations on it. *In the meantime, work on some of your own!
Thankfully, they call it "theory". *I'm not sure what the proper technical name for these would be, but....they usually sound good. *We'll just ask Chris. *:-)
More to come, including:
• Pinch Harmonics!
• Tapped Harmonics!
• Right-Hand Sliding!
Old 01-05-2002, 01:53 PM
Giant Steps  is offline
Posts: 54  -  iTrader: (0)
Here's some with sweeps.
[font=courier new]
* * * * * * * * * * * * T * * * * * * * * T
&amp;#0124;----------------12h15-19p15p12-----------------------------&amp;#0124;
&amp;#0124;-------------14----------------14--------------------------&amp;#0124;
&amp;#0124;----------12----------------------12h14-18p14p12-----------&amp;#0124;
&amp;#0124;-------14----------------------------------------14--------&amp;#0124;
&amp;#0124;-12h16----------------------------------------------16p12--&amp;#0124;
&amp;#0124;-----------------------------------------------------------&amp;#0124;
* * * * * * * * * * * *T * * * * * *T * *T
&amp;#0124;----------------12h15-19p8p5-------------------7----&amp;#0124;
&amp;#0124;-------------13--------------6----------------------&amp;#0124;
&amp;#0124;----------12-------------------5h7-12p7-14p7p5------&amp;#0124;
&amp;#0124;-------14-------------------------------------------&amp;#0124;
&amp;#0124;-12h15----------------------------------------------&amp;#0124;
&amp;#0124;----------------------------------------------------&amp;#0124;
* * * * * * * * * * * * T * * * * * * * * * * * * * * * * * *T
&amp;#0124;------------------8h12-17p12p8-------------------------8h12-20p17p12-------------&amp;#0124;
&amp;#0124;---------------10--------------10-------------------10---------------13----------&amp;#0124;
&amp;#0124;-------------9--------------------9---------------9---------------------14-------&amp;#0124;
&amp;#0124;----------10------------------------10---------10--------------------------14----&amp;#0124;
&amp;#0124;-----7h12------------------------------12p7h12--------------------------------15-&amp;#0124;
&amp;#0124;-5h8-----------------------------------------------------------------------------&amp;#0124;
* * * * * * * * * *T * * * * * * * * *T * *T * *T * * * * *T *T
&amp;#0124;-------12p0-12h15-18p7p6-----------8-------------------------------------------&amp;#0124;
&amp;#0124;-------------------------7-------7--------18p7---------------------------------&amp;#0124;
&amp;#0124;---------------------------6p0-8-----19p8------19p8-0--------------------------&amp;#0124;
&amp;#0124;-12h14-------------------------------------------------------13p8p5------------&amp;#0124;
&amp;#0124;------------------------------------------------------4h7-12--------8p5--------&amp;#0124;
&amp;#0124;------------------------------------------------------------------------8p0----&amp;#0124;
[/font]
Enjoy!
-VIG-
Old 01-05-2002, 03:16 PM
trouble311  is offline
Posts: 643  -  iTrader: (3)
Just wondering guys (and this question is basically directed towards all of you who use tapping as a normal tool everyday), when you tap with the fingers on your right hand, do you pull the string sideways off the fret you are tapping? *Like almost plucking it? *Just wondering, because sometimes just downwardly tapping doesn't produce enough sound....my technique is usually to pull the string slightly sideways when I tap, so it is like: *tap, pull sideways at a downward angle, then hammer-on with left hand......is this what you guys do, too, or is there a better way?
Old 01-05-2002, 03:53 PM
Devine  is offline
Posts: 171  -  iTrader: (0)
My comment is not really a trick per se, but some advice on using tapped notes compositional. *Tapping attacks starkly contrast picking attacks creating tension. *Try following strings of picked notes with half-time feel taps ascending or descending in a scalar fashion. *
* * * * * * * * * * * * * * * * * T * * * * * * T * * * * * * T
(fast blah) slow ---13---20---13---23---13---23
This works well if A# is the note you're cadencing to. *I know my explanation isn't so hot, but listen to John Petrucci; he does this well.
0:47-:48 on Universal Mind by LTE and then also on "Damage Control" from the G3 tour.
-Devin
Old 08-18-2003, 03:50 PM
atifman  is offline
Posts: 10  -  iTrader: (0)
Re: Lesson 13: Tapping overview - right hand technique
where specifically?
Old 08-18-2003, 07:50 PM
zEr0  is offline
Posts: 1,223  -  iTrader: (18)
Well according to the tab you get on the net he does it at the beguining of the song. HOwever that's not what he does in the San Francisco Live DVD.
Old 08-28-2003, 02:06 PM
Bar_Hook  is offline
Posts: 105  -  iTrader: (0)
i love that legato/tapping thing he does at the end of crush of love on that dvd
Old 09-16-2003, 06:07 AM
Fink Floyd  is offline
Posts: 21  -  iTrader: (0)
Paul Gilbert's tapping intro to Green-Tinted Sixties Mind is another great introduction to tapping - fairly easy, but sounds incredible. It also includes a couple of alternative tapping techniques, eg sliding taps.
Devine - that looks like a really neat idea. Seems to me it'd sound quite like the end of Vai's mental tapping lick from Hand on Heart. How do you know which notes to pick in this situation? Is it just scale patterns?
Old 10-16-2003, 06:35 AM
Bar_Hook  is offline
of course u cud never go wrong with the tapping vai does in his G3 end of Answers guitar solo; beautiful stuff, I like to see the full thing tabbed out, theres a powertab file of it out there sumwhere, but the tapping is COMPLETELY off.
Old 12-15-2003, 07:56 PM
woodros  is offline
Posts: 303  -  iTrader: (0)
i agree that tapping/ solo that vai does on g3 is amazing, what pees me off is how clean it is, but when i try to do it i often find myself having alot of noise even though im doing my best to mute the strings i dont need, i also cant stand tapping like vai does with his middle and ring fingers while still holding the pick, im afraid its pick in the mouth for me. i dot know if this is right at all but the basic thing i try to do is this first with the left hand part:
e----------9h12------------9h12
b----9h10-------10p9h10-------
i know vai does all sorts with the rhythm but i cant be arsed.
the tapped bit i do just goes like this:
e---1616--1616--
b-16-----16--------
and then every now and then a slide up to the 17th fret on the top string
if anyone can show me how they would play that would be great, because i had a crappy tab too, and had to virtually learn the thing from ear, which isnt always right for me.
Old 12-16-2003, 07:20 AM
Bar_Hook  is offline
on www.powertabs.net there is a new tab which has much more accurate tapping; give it look...
Old 01-15-2004, 11:23 PM
The Madness Here  is offline
Posts: 249  -  iTrader: (0)
Another good example of more chord based tapping is Satch's Day at the Beach.
Old 05-10-2004, 12:25 PM
Cordokiller  is offline
Posts: 15  -  iTrader: (0)
Hi folks!!, If you really like tapping, you must see STANLEY JORDAN, he has the most incredible tapping technique that i've ever seen, and in the Heavy world, KIKO LOUREIRO from brazilian band ANGRA
eric johnson, jennifer batten, joe satriani, john petrucci, kiko loureiro, michael romeo, paul gilbert, pinch harmonics, stanley jordan, steel strings, steve vai, van halen
