<back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 03-17-2003, 12:48 PM
jem7vwh  is offline
Posts: 1,583  -  iTrader: (3)
Reviews: 4
here's another fun arpeggio to try
Code:
Gtr I (E A D G B E)
  4/4
   Gtr I
                T          T          T          T          T
   T T T T T T  T T T T T  T T T T T  T T T T T  T T T T T  T T T T S
||---------2h5h12p5p2---------------------------------------------------|
||-------3------------3h5h12p5p3----------------------------------------|
||-----2-------------------------2h4h12p4p2-----------------------------|
||---4--------------------------------------4h5h12p5p4------------------|
||-5---------------------------------------------------5h7h14p7p5h7p5---|
  W
|-5----|
A little explanation: The first row of Ts above the tab is the measure, 32nd notes The second row is Tapping Articulation. So when you see a T in the upper row, it means you're using right hand technique
Old 03-17-2003, 12:54 PM
jemsite  is offline
Administrator
Posts: 9,259  -  iTrader: (5)
Images: 11
FYI - you can use the code tag to monospace fonts for TAB
[ code]
[ /code]
without the spaces
Old 04-20-2003, 08:49 PM
baileyk85  is offline
Posts: 34  -  iTrader: (0)
I've been trying sweep picking for a good few months now but I still have some technique problems with it. Mainly on stopping the notes ringing out on the downstrokes. The upstrokes are fine because my right hand palm cuts off the notes.
I'd be grateful if someone could give me a few technical hints.
Old 07-30-2003, 07:51 PM
Satch Boogie  is offline
Posts: 103  -  iTrader: (0)
Although Im not good at sweep picking my self, but I know how you are supposed to do it. The guitarist that showed me was Joe Stump, ya him, the 6th fastest guitar shreder of all time, just 3 behind Yngwie Malmsteen. Stump is just about the fastest guitarist ive ever heard. Who else can play 16th notes at like 350 CLEAN, and like actual riffs going up the neck. Just wow.
OK. For riffs like the one posted above out of Tender serender where u have 2 or 3 notes u have to hit and they are all on the same fret, you do bar, but you do not use any right hand muting. You have to "roll" ur finger from the first string int that fret to the last. If it is like 3 strings u have to do this to, you hit the first (if ur going from high e down) right about where ur finger bends (below ur finger nail). The top of ur finger should be pointed up so its not on the other strings. Then you "roll" ur finger down hitting each note, then you do the same thing to go up, u just reverse it. Hard, ya, but its the easiest and cleanest way to do it. And yes, in the end its the best way, just take it from the best guitarists out there.
Old 08-19-2003, 12:59 AM
LGMT  is offline
Posts: 364  -  iTrader: (0)
Example of minor one in A:
------------------------------8----12----8-------------------------------
-----------------------10---------------------10-------------------------
-----------------9-----------------------------------9-------------------
-----------10---------------------------------------------10------------
------12---------------------------------------------------------12------
You can use only "half arpeggio". Sounds cool too. Hehehehe......
sweep!
A Minor:
---------10--------------------10-------
-----9-------------------------------9---
A Major:
------------------------------9----12----9-------------------------------
-----------11---------------------------------------------11------------
Old 01-11-2005, 11:01 PM
jim777  is offline
Re: Lesson 8: Arpeggios - could not post to Theory section?
Lesson 8
joe stump, minor scales, picking technique, sweep picking, yngwie malmsteen
