Players, People, Music and Tours
Guitar Lessons & Music Theory
middle or ring finger???
Post any type of guitar or music lessons, theory and other learning methods.
04-13-2006, 05:36 PM
King Nothing
Posts: 333 - iTrader: (
when i learned my basic modes, lets just take A major starting on the 6th string(3 notes per string), I would use fingers 1,2, & 4 for frets 5,7,9. I just got a book that says to use 1,3, & 4. That's alot harder for me, probably because I'm not used to stretching my pinky and ring finger so far apart. Should I relearn it this way? Will my fingers eventually get used to it so it's not so painful? Does it really even matter in the end? Thanks
-Chris
06:51 PM
King Nothing
Find all posts by King Nothing
04-13-2006, 06:08 PM
andy7jem
Posts: 6,504 - iTrader: (
Re: middle or ring finger???
I've been playing quite a few years and i'm still confused
I find 1,2 & 4 more comfortable up to the 12th fret and 1,3 & 4 above the 12th fret!!
andy7jem
Find all posts by andy7jem
04-13-2006, 06:51 PM
King Nothing
okay, so its not really set in stone. I just wanted to make sure I wasn't doing it wrong and would find out a few years down the road that if I did it a certain way, everything would be a whole lot easier
King Nothing
04-13-2006, 07:28 PM
toneboy
Posts: 1,665 - iTrader: (
I've played for 15 years and I used whatever gets the job done. You can used to almost anything but some fingerings are just uncomfortable for some people. As long as you think about which fingers you're using and understand what the ramifications of your choices will be (e.g. can't bend a string with your pinky), you're fine.
toneboy
Find all posts by toneboy
04-13-2006, 07:49 PM
Mister CCJ
Posts: 311 - iTrader: (
usually when i do an A major or ionian run (3 notes per string) ill use 1,2,4 fingers for the 5-7-9 frets cuz when i get to the d-string (6-7-9) which ill use 1,2,4 fingers; its an easier transition on the hand. say when i do an A phrygian run from low-e to high-e 5-6-8, 5-7-8, 5-7-8, 5-7-9, 6-8-10, 6-8-10 ill use fingers 1,3,4 on those last 5 strings because of the transition on the hand. does that make any sense to anyone else? lol. and yeah after the 12th or so fret its hard to go 1,2,4 due to the hand position.
Mister CCJ
Find all posts by Mister CCJ
04-13-2006, 08:49 PM
Eggy
Posts: 1,751 - iTrader: (
I would seriously consider switching to 1-3-4 as IMO it promotes speed and clean legato. I've been playing 22yrs now and had to make that switch in technique about three yrs ago. The further down the line you get before making changes , the harder those changes are to implement.
Just out of interest I use 1-3-4 for the E and A strings over frets 5-7-9 but swith to 1-2-4 for the D and G string over frets 6-7-9.
But I'm a left handed guy who plays guitar right handed so I've just gotta go with what gets results
Ben
Eggy
Find all posts by Eggy
04-13-2006, 09:55 PM
mi2tom
Posts: 7,522 - iTrader: (
I uses 1,3 and 4 a lot perhaps I like to watch my middle finger hanging up when playing
mi2tom
Visit mi2tom's homepage!
Find all posts by mi2tom
04-13-2006, 10:16 PM
JESTER700
Posts: 2,234 - iTrader: (
I'm with Andy - it depends on how high I'm playing. 1-3-4 on higher frets, 1-2-4 on lower ones.
JESTER700
Find all posts by JESTER700
04-14-2006, 09:04 AM
andy7jem
mi2tom
I'd never really thought about that until some-one pointed out to me it looked like i was giving them the one finger salute
andy7jem
04-14-2006, 07:51 PM
Mister CCJ
also i noticed that when i do a 3-note-per-string dorian run ill do the 5-7-8 fret with my 1,2,3 fingers on the low-e as an easier transition to the 5-7-9 with my 1,2,4 fingers that way i dont have to shift any fingers IMO like i said before i think the less fingers u have to take out of position out of whatever run ur doin the smoother it will be thats how i base whether its 1,2,4 or 1,3,4 fingers ur fingers will get comfortable to adapt with time and u wont have to think which finger to use
Mister CCJ
04-15-2006, 01:31 PM
Ant1981
Posts: 2,181 - iTrader: (
which ever she likes best
Ant1981
Find all posts by Ant1981
04-15-2006, 11:59 PM
Cozi101
Posts: 260 - iTrader: (
Good one!
Cozi101
Find all posts by Cozi101
04-16-2006, 01:34 AM
gu1tar
Posts: 858 - iTrader: (
The 1,2,4 fingering is the is the technically "superior" way. But, hey, there are plenty of guitarsts who only play with 3 fingers while that pinky naps.
Let's take an A Ionian as an example. If you use fingers 1,2,4 on the low E and A strings (5-7-9) and transition to the D string (6-7-9), it's a smoother transition with the first finger moving and the hand position not having to change. If you used 1,3,4 for the 5-7-9, the transition to the D string takes more movement and more movement makes it slower and less smooth. The Aeolian mode is even more of a wreck on the D,G,B, and E strings if you were to use 1,3,4.
gu1tar
Find all posts by gu1tar
04-20-2006, 06:50 PM
Mister CCJ
ok so im not the only one that does this lol
Mister CCJ
04-20-2006, 07:06 PM
Ant1981
actually yea, i do that too, i watched one of the guitarists from the scorpions play like that, which put my mind at ease.
Ant1981
guthrie govan
joe satriani
steve vai
yngwie malmsteen
i cannot figure out how to finger pick at all
what is the lengh a finger
when your deaf does your ears ring
what is that ring thing that herman li uses
when to use middle pickup
Crazy ring finger when hamering
OuterBody
07:21 PM
legatos
riskordie
02:23 PM
Middle position single coil recommendations
autospork
Pickups & wiring
10:56 PM
Plucking with fourth finger on right hand
007
03:46 PM
New P'ups in my JEM - ...bridge and middle replaced...
kennydoe
11:55 PM
06:17 PM
