<back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 06-23-2001, 08:13 PM
ElliotG  is offline
Posts: 4  -  iTrader: (0)
Practicing - clean or distorted?
hey guys,
Im just wondering...do you guys practice scales, arps, sweep picking..etc..on a clean or distorted tone?
thanks,
Elliot
Old 06-23-2001, 08:51 PM
jem7vwh  is offline
Posts: 1,583  -  iTrader: (3)
Reviews: 4
Practicing
both!
* practice clean to make sure you are articulating the notes clearly and to work on your accuracy
* practice distortion to learn how to control your tone, feedback and to produce the right vibrato, and harmonics.
Also, there are some passages that just don't sound right without the right tone. *So if you're practicing a phrase that doesn't sound right, make sure you try it out distorted and see if that isn't the difference.
Old 06-23-2001, 08:58 PM
ElliotG  is offline
Practicing
thanks a ton.
Old 06-25-2001, 11:06 PM
chilln2music  is offline
Posts: 264  -  iTrader: (1)
Practicing
Here's something I noticed...
Practicing Clean- I do this 90% of the time I play guitar to concentrate on precise and accurate playing but I tend to get so involved on the mechanics I can't relax therefore hindering my max. potential---I know this for a fact because....
Practicing Distorted- I can concentrate more on the music (which its all about anyway right!) and play faster with as much accuracy as clean.
I still practice clean because I do want to be accurate and believe this or not but...PRACTICING SLOWLY DOES HELP (me at least). I noticed that if I practice say the A aeolian mode in 5th position for 20 min. at 112 bpm 16th notes I will be able to play faster and accurately when I crank the distortion instead of practicing it at 144bpm. That's just what I've found out (I think because you are playing it ACCURATELY so many times as opposed to "somewhat accurate")
Old 06-27-2001, 05:10 PM
kennydoe  is offline
Posts: 3,416  -  iTrader: (1)
Practicing
Mostly I practice without an amp...usually in front of the TV or at the computer while reading the forum pr the newspaper.
Probably not good habits
~Kenny
Old 06-27-2001, 05:47 PM
Mirrored CAT  is offline
Posts: 115  -  iTrader: (0)
Practicing
Kenny, that's not harmful, but you need to practice with an amp with the volume reasonably up, so that you can hear any noise extra that you're making. Practicing without amp will make you believe that your technique is perfect, and you'll not mute al the undesired sounds because you can't hear them.
Old 06-28-2001, 12:13 PM
GhesQi J  is offline
Posts: 221  -  iTrader: (0)
Practicing
I agree with CAT.
When turning up the volume there's so much undesired "noise" that can't be heard when playing more quiet or unplugged.
But I must admit that I also practice alot unplugged or more quiet. (don't want a fight with the neighbours )
As for playing clean or distorted, I also do both to enchance my technique.
Cheers,
Joten
Old 06-28-2001, 04:01 PM
Josh Blagg  is offline
Posts: 340  -  iTrader: (0)
Practicing
There's more than just noise you need to address when practicing plugged versus unplugged. *If you are plugged in, your dynamics are much more evident. *More importantly though, you will find that the way you fret the note really shows, especially with your distorted tone. *Sometimes I can practice unplugged and think I am playing pretty good, but when I plug in using the same technique, it sounds bad through the amplifier. *I also think it is important to practice at the volume you would usually play at, as your amplifier will be a different animal in many aspects, not just noise.
Old 07-31-2001, 03:02 PM
AJ Love  is offline
Posts: 119  -  iTrader: (0)
Practicing
I practice with an amp plenty too, but MOST of my practicing is without an amp...thats an old trick that Eddie Van Halen claimed to use way back in the day, practising without an amp...
Old 07-31-2001, 06:51 PM
lgascoig  is offline
Posts: 286  -  iTrader: (0)
Practicing
I practice clean through an amp whenever I am working on speed or technique about 80% of the time. *I play the other 20% with distortion so I can work on muting. *Of course, when I actually play a piece I use the appropriate amount of gain for it. *I have a very loud metronome for practicing my Rock Robotics.
Old 08-01-2001, 12:54 AM
trouble311  is offline
Posts: 643  -  iTrader: (3)
Practicing
I am a big fan of both too....clean for tech and picking, etc....dirty for FUN!!!
Old 02-07-2010, 12:35 AM
theapprentice  is offline
Posts: 171  -  iTrader: (0)
Reviews: 21
Re: Practicing - clean or distorted?
Guys, how about a dirt tone with more headroom, so that the notes would ring out clearer, but the imperfections of one's technique would also be audible when doing difficult licks? I personally find this the most challenging way to practice my complex chops.
Old 02-07-2010, 01:12 AM
CosmicDebris  is offline
Posts: 3,216  -  iTrader: (4)
I like my sound like I dig my women just a little dirty.
Old 02-11-2010, 11:18 AM
stacey  is offline
I normally practice both, but mostly unplugged. I need to put more effort into an unplugged guitar, particularly for trill and legato work, and what I've found is that when I plug in, and kick on the dist I can play a lot lighter and everything seems a bit faster and smoother.
Old 04-04-2010, 11:04 PM
Hobophobic  is offline
Posts: 260  -  iTrader: (0)
Re: Practicing
Me too... and not nearly as often as I used to. My playing (which was never that great) has gone downhill as a result. I should be ashamed.
distorted tone, eddie van halen, sweep picking, van halen
