<back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 03-09-2008, 07:19 PM
vejiita  is offline
Posts: 56  -  iTrader: (0)
question about theory!!
can you give me the notes of the
c major scale- c, d, e, f, g, a, b, c
c minor scale-
c pentatonic scale-
c blues scale-
c major triad- c, e, g
c minor triad- c, e#, g
c major 7 triad-
c minor 7 triad-
c dominant 7-
c minor 7 flat 5-
Old 03-09-2008, 11:02 PM
choubix  is offline
Posts: 235  -  iTrader: (0)
Re: question about theory!!
http://www.jazzguitar.be/guitar_chord_finder.html
you can get all the scales + intervals on this chord finder.
hope this will help.
Old 03-10-2008, 01:34 PM
MattyCakes  is offline
Posts: 245  -  iTrader: (2)
all the minor scale is... is the 6th degree of the major scale, so in theory would would be playing an A major scale, which is ABCDEFGA
Old 03-10-2008, 02:29 PM
eelblack2  is offline
Posts: 865  -  iTrader: (4)
c major scale- C, D, E, F, G, A, B, C
c minor scale- C, D, Eb, F, G, Ab, Bb, C (Difference to Major lowered 3rd, 6th, and 7th)
c pentatonic scale Major - C, D, E, G, A
A pentatonic scale minor - A, C, D, E, G
c blues scale- (Depends on your historical level of correctness, but most guitar players simply add the flat5 to Major Pentatonic) (The true/traditional blues scale is much more complicated than that but lets keep it simple)
c minor triad- c, e#, g (Not Correct - Harmonic spelling C, Eb, G)
c major 7 triad- (No such thing unless you omit the 5th - 4 note chord spelled C, E, G, B)
c minor 7 triad- (Same deal as above - 4 note chord spelled C, Eb, G, Bb)
c dominant 7- (C, E, G, Bb) (Major triad with a lowered 7th degree on top)
c minor 7 flat 5- (C, Eb, Gb, Bb)
Corrections/answers made above.
Last edited by eelblack2; 03-11-2008 at 11:37 AM. Reason: Corrected the relative minor mis-type on my part
Old 03-10-2008, 08:46 PM
The Euphor  is offline
Posts: 2,948  -  iTrader: (4)
C pentatonic scale minor - C. Eb, F, G, Bb
I beg to differ. There is no such thing as "one" pentatonic major/minor scale. As long as the thirds are major/minor (and the intervals are two minor thirds and three seconds) you have several options - and they all are pentatonic.
Old 03-11-2008, 01:31 AM
vejiita  is offline
thanks!!
Old 03-11-2008, 11:02 AM
Agreed, I was speaking in precise major/relative minor terms because it sounds like that is something the original poster needs to get a grasp of. My background is purely traditional classical theory as opposed to modern or jazz style theory, so I will always err on the side of non-harmonic ambiguity.
I corrected the mispost on the relative minor to C major pentatonic. I meant "A" in my head but I forgot to backspace over the original poster's "C".
Old 03-17-2008, 02:24 PM
GurraSj  is offline
Posts: 2  -  iTrader: (0)
Dont forget this one, the Harmonic Minor, its a killer
A harmonic minor: A, B, C, D, E, F, G#
Old 03-17-2008, 09:31 PM
Smitty  is offline
Posts: 841  -  iTrader: (1)
Also, can't forget two very important jazz scales. That is, if you care.
Melodic Minor (ascending; descending is just the natural minor scale)
C-D-Eb-F-G-A-B-C
Half/Whole scale
C-Db-Eb-E-F#-G-A-Bb-C
Explore with those and you'll have loads of fun.
smitty
Old 03-17-2008, 09:41 PM
markyperfection  is offline
Posts: 233  -  iTrader: (0)
spoken like a true shredder!
Old 03-17-2008, 09:58 PM
Meedlyx10  is offline
Posts: 72  -  iTrader: (0)
That only holds true in classical/compositional contexts. When used for soloing/improv it's just as you posted it regardless of the direction of the line and is generally referred as "real" melodic minor to differentiate.
Old 03-18-2008, 07:01 PM
Smitty  is offline
Good point. In classical, the leading tone almost always means a return to the tonic, and the raised sixth is used to smooth out this transition. But also, in classical, once you reach the tonic, a descent down the natural minor scale is common. Thus the dual scale sorta thing.
But yes, in jazz, all you really use is the ascending part, and really you're just playing the dorian, using the raised seventh as a passing tone or a grace note, to start a phrase.
smitty
Flextone II Setting Question Two hands31 Gear and Equipment 17 06-20-2003 01:59 PM
Question: How to balance the EQ on MT-2 with the EQ on amp? seventhsign Gear and Equipment 9 03-18-2003 02:47 PM
Simple question, simple answer? jsdetrait Tech: Setup, Repairs and Mods 10 01-13-2003 02:32 PM
quick question Creep Other 6-string Guitars (non-Ibanez brand) 3 10-21-2002 02:37 PM
A simple question concerning the sound of RG3120 particlestorm J-Custom, USA Custom & Prestige Ibanez Guitars 6 04-11-2002 04:48 AM
