<back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 07-16-2002, 03:57 PM
Jeff  is offline
Posts: 1,501  -  iTrader: (1)
Satches tremelo picking and pick tapping technique
Do you guys have any tips on getting these 2 techniques down? He just uses his wrist to do the both. I think Vai has the same technique for tremelo picking. I tremelo pick more like Mike Knealy, with my whole arm. This way isn't very efficient and gets extremely tiresome. Any help would be appreciated.
Old 07-16-2002, 08:05 PM
Vai the god of Sound  is offline
Posts: 232  -  iTrader: (0)
I'll try to be as politically correct as possible, but hold your forearm on a table or desk, but have you wrist and hand off the surface...allowing it to move freely.
Simply repeat moving your wrist up and down with a closed fist. Repeat up and down at a reasonable pace until you're going in roughly the same angle up and down...then increase your speed...this should work the muscle and make your wrist recognize the motion.
Also, try holding you arm horizontally in mid-air and move your wrist up and down as fast as possible....
Remember to use only your WRIST MUSCLES
Then try it with a pick on your guitar...start off slow
Hope this helps.
Old 07-17-2002, 12:11 PM
Kev Brigden  is offline
Posts: 496  -  iTrader: (0)
Originally Posted by Vai the god of Sound
I'll try to be as politically correct as possible..., but have you wrist and hand off the surface... allowing it to move freely...
Hope this helps.
oo err...
Old 07-19-2002, 03:56 PM
ripl3y  is offline
Posts: 747  -  iTrader: (0)
You gotta' relax that wrist.
Try working on some funk, it helps me.
A tip from Rowan Robertson was he used to wear a heavy ring on his right hand pinky which helped with a sort of pendulum effect.
Maybe give that a go.
Steve
