Players, People, Music and Tours
Guitar Lessons & Music Theory
Smoother picking motion?
Post any type of guitar or music lessons, theory and other learning methods.
03-18-2003, 05:09 PM
Swirly
Posts: 430 - iTrader: (
Hi there. I have recently been practicing my left/right cordination and using a metronome to go chromaticly up the fretboard. Now im not that fast, i practice at the moment on about 92bpm and playing 4 notes per beat. Its not fast, but if i go higher im likly to make mistakes.
I use a normal
alternate picking
motion, and use Dunlop .71's (purple ones).
After a while of playing i seem to naturally get into a pattern of just moving over the string, rather than digging in to it.
But are there any other things i can do to make the attack on the strings smoother, therefore giving less resistance when moving across the strings? I try to somtimes hold my plectrum at an angle so it slices diagonaly, but any other things would be great.
Ta
Swirly
Find all posts by Swirly
03-19-2003, 01:56 AM
Rabin
Posts: 97 - iTrader: (
Re: Smoother picking motion?
Swirly
Ta
That's what I try to do to gain a little more speed but sometimes I feel that you loose a little note definition when the pick's side just brushes against the string!
Rabin
Visit Rabin's homepage!
Find all posts by Rabin
03-19-2003, 08:51 AM
bryangraye
Posts: 128 - iTrader: (
If you build up your finger strength, you can rely less on your picking hand, and more on hammer on sequences (with every finger), although in the end it's still a combination of the two.
bryangraye
Find all posts by bryangraye
03-19-2003, 12:28 PM
Ash
Posts: 68 - iTrader: (
Well, of course you could do that, but it's not picking! great exercize for legato though.
for the picking, what i do is start off really, rrreeeeaaaalllyyy, slowly, and play scales up and down in all positions (I usually use E minor pentatonic). when i'm done going through the shapes, i put the metronome up by one click, and do it over again. if you spend a half hour a day doing this, you should be able to pick like theres no tommorrow in a month or so!
Ash
Find all posts by Ash
03-19-2003, 03:53 PM
BrianH
Posts: 599 - iTrader: (
Get a stylus pick and pick with that when you practice your chromatic excercises. It'll teach you how to properly pick and give your picking hand a 'memory' implant.
BrianH
Find all posts by BrianH
03-19-2003, 05:35 PM
ShredOrDead
Posts: 222 - iTrader: (
Get a thicker pick -- at least 1.14 mm.
ShredOrDead
Find all posts by ShredOrDead
07-12-2003, 05:10 PM
markgibson
Posts: 17 - iTrader: (
If you want to change your pick to get faster, try using Dunlop JazzIII's. They're tiny little picks and an aquired taste but once you get used to them you can control it way better than a normal-sized pick. I used to swear by 2mm picks until I got some of those.
Ooo,
Shawn Lane
and
John Petrucci
use them too and I'm not going to argue with them
markgibson
Visit markgibson's homepage!
Find all posts by markgibson
07-13-2003, 03:28 AM
The_Grindfiend
Posts: 668 - iTrader: (
Wow, I didn't know any other guitar player in the world liked the 2mm picks. I love them! I was almost embarassed to mention it, though.
The_Grindfiend
Find all posts by The_Grindfiend
07-13-2003, 04:30 AM
disassociative1
Posts: 585 - iTrader: (
i was just wondering do u people consider a fast legato run with pick hammer hammer pick hammer hammer triplets alot easyer than picking every note??
i use legato alot for the beautiful fluid feeling and sound it gives, ala
joe satriani
, and i just love playing like that
disassociative1
Visit disassociative1's homepage!
Find all posts by disassociative1
07-13-2003, 08:38 AM
markgibson
Fast legato runs definently have a different feel to straight picked runs, picked runs can sound much more aggressive. It's quite hard to get a totally fluid sound ascending when using hamer-ons. An interesting way of ascending with hammer-ons is to hammer-on with the first finger instead of picking
markgibson
07-13-2003, 07:41 PM
Devo
Posts: 1,482 - iTrader: (
i think the general consensus among the pick shredders is to generally use the paul gilbert/petrucci-ish sort of style.
Basically use a heavy pick like a jazz three (the black ones not the red ones) or a stubby. a light pick will always be a couple of mm behind your hand, hence you need to make bigger wrist movements to actually pick the string, and because you need to move your wrist more you abviously cant play as fast. (heavey pick smaller movements)
controll of attack is achieved by how much plectrum makes contact with the string. the lighter the contact the quieter the sound. To change attack or increase volume dont pick harder but rather move the pick towards the body of the guitar so that more pick moves accross the string..
more deflection of string = more volume.
generally if you use any pick for about two weeks you will become completely acoustomed to it, so dont let that put you off.
I personally prefere (Black) jazz3's cause they give a very recognizable petrucci sound.
Stubbies are slippier and are a great shred pick but i dont like the plastic sound the impart on the tone. I know lots of people who love em though.
best of luck
Steve
Devo
Find all posts by Devo
07-13-2003, 07:44 PM
Devo
oh and your best bet is to keep the pick as flat to the string as possible ... any kind of angle is just going to give you a scratchy sound to you picking.
Devo
07-13-2003, 07:54 PM
btweensunandmoon
Posts: 221 - iTrader: (
personally...i hold my pick exactly perpendicular to the strings. That gives me a very well defined sound and I tend to dig in a tad just to give me that extra presense. The only way to get smoother playing is to practice your ass off. Theres no secret trick. The stronger your wrist and forearm get, the smoother your playing will feel and sound. And just as has been said before, dump the thin pick for a 1mm or heavier. I use fender nylon 1mm picks and I wouldnt think of using another. The things just refuse the wear out.
btweensunandmoon
Find all posts by btweensunandmoon
07-23-2003, 01:51 PM
baileyk85
Posts: 34 - iTrader: (
I was watching Zakk Wyde on Live At Buddokan and he seems to pick quite a bit with his elbow.
I always thought you were never meant to do that but I've tried it all the same and you can pick very smoothly although I'll admit you have a lot less control so more complex passages are a lot tougher.
baileyk85
Find all posts by baileyk85
07-26-2003, 07:05 PM
Swirly
Hmm.Ive been watching my picking hand in a mirror latly and i noticed that although i make very small movements i hold my Jazz III in the way that its at about 45 degrees to tjhe string, rather than exactly straight next to this. I realise that this effect the tone a bit but imo its not that bad, there arnt any other problems with this angle are there?
Swirly
alternate picking
joe satriani
john petrucci
neck pickup
paul gilbert
shawn lane
what muscle is responsible for picking speed
what is legato picking?
what is anchoring picking
what is elbow picking
is picking hand pain good?
06:43 AM
