<back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 02-07-2006, 10:39 PM
newbieguitarmaker  is offline
Posts: 4,030  -  iTrader: (5)
Images: 1
steve vai style question
i've noticed that vai uses a lot of harmonics for screams but sometimes it looks as if he is bending the harmonic, is he bending a harmonic or is it something else? and how do u do it?
Old 02-08-2006, 01:28 AM
technomancer  is offline
Posts: 663  -  iTrader: (6)
Re: steve vai style question
I think what you're talking about is a pick harmonic... basically when you pluck the string you also touch it with the thumb of your pick hand to produce the harmonic, which allows you to bend the fretted note just like any other.
Old 02-08-2006, 02:22 AM
lyconxero  is offline
Posts: 1,469  -  iTrader: (0)
Ah, yes. They are also referred to as pinch harmonics since you are essentially pinching the string between the pick and your finger. It's not an easy trick to grasp initially but once you get the major idea then it just takes a LOT of practice to get to the point where you can make them wherever you want, anytime you want.
Old 02-08-2006, 05:35 PM
Images: 1
oh, i have been experimenting with pinch harmonics. so he bends the pinch harmonics?
Old 02-08-2006, 07:03 PM
btangel  is offline
Posts: 541  -  iTrader: (1)
yea kinda. Some people get it slow, but once you get it, it pretty much sticks to you. Also the harmonic sounds different depending on where you "pinch" the string. Just experiment!
Old 02-08-2006, 07:22 PM
vy100  is offline
Posts: 410  -  iTrader: (2)
Reviews: 3
You can use pinched armonics, as explain above, but you can also raise or depress a natural armonic with the tremolo arm. Steve uses both...and other tricks never thought.
Old 02-09-2006, 07:56 PM
Images: 1
but when he bends the string is he using a pinch harmonic with it or some other harmonic?
Old 02-10-2006, 07:48 AM
drizzt75  is offline
Posts: 129  -  iTrader: (0)
pinch
Old 02-10-2006, 10:12 AM
wallie!  is offline
Posts: 352  -  iTrader: (0)
heh, once you get it you cant stop :P
newbie give us an example in one of his songs so we can work it out what you are exactly taking about.
Old 02-10-2006, 06:55 PM
Epicus Furor  is offline
Posts: 519  -  iTrader: (0)
Cool
There are loads of tricks Steve uses with pinched harmonics and whammy bar to create some cool effects.
Here's a few:
The Horse
OK, here is an Eddie Van Halen-trademark, often called "The Horse". The way to do this is: hit an harmonic at the fifth fret, press down the bar while shaking it forth and back, then let it move up again, pull up a bit more (above standard pitch ) and down again...
The purring cat
This is an effect made popular by Steve Vai... used i.e. in "Blue Powder". But Steve Lukather is another player who uses it a lot, as i.e. in the Toto-Song "Dave´s Gone Skiing", from the "Tambu"-Album...
It´s kinda difficult to describe. First of all, you need a properly setup FLOATING doublelocking system.Set the bar so it is parallel to the strings, pointing towards the headstock. Then, while playing notes with the left hand, slam down your right hand onto the bar. Let your hand slide along the bar and slide off of it... if you do it right ( I hope you get the idea from my description ), the whole bridge will shake / vibrate fast, and thereby create a shake-y sound, kinda like a purring cat.
Steve Lukather had another nice trick: While playing trills with the left hand, he slightly pushes down the bar and lets it come up again... that way, he creates some kind of a "whirly", "drunk" effect.
Steve Vai took that to another level with his "windmill" ( He used to do that a lot live and in videos with David Lee Roth ).
Another cool trick Vai and Satriani use is to depress the whammy bar as low as possible, then gradually whilst raising it, with your right hand, pick pinch harmonics on the open G-string ( yes, those high-pitched, squealing harmonics a la Billy Gibbons... immediately after you pick the string, touch it slightly with the side of your thumb or the nail of your pinkie to turn the picked note into an harmonic...
Hope some of these neat tricks help ...
- PLAY LOUD -
Old 02-11-2006, 12:28 PM
mi2tom  is offline
Posts: 7,522  -  iTrader: (4)
Originally Posted by Epicus Furor
- PLAY LOUD -
and clean
Old 02-11-2006, 02:19 PM
Chris From Singapore.  is offline
Posts: 462  -  iTrader: (0)
As mentioned above pinched harmonics occur when the flesh on the thumb of your picking hand touches the string when you pick it. Usually to get the best results it has to happen almost simultaneously. Pick the note and then immediately, while on the downstroke, "hit" the string with your thumb.
Experiment with different portions of the string. Which means to say from the bridge pickup area to the neck pickup area. Different parts will yield different notes, which is basically the whole principle of harmonics.
For best results crank up the gain and add some treble, also use your bridge pickup.
What Vai does is basically bend the string while doing a pinched harmonic. You can also achieve the same thing, but not exactly; with your whammy bar.
Experiment!
Old 02-11-2006, 03:20 PM
Chris777  is offline
Posts: 340  -  iTrader: (2)
Pinch Harmonics are cool, if you really want to hear somebody play PH's on every note listen to some Zakk Wylde. If you want to sound like Vai play the lydian scale in hyperspeed, and learn how to tap like a friggin stenographer
Old 02-12-2006, 02:01 PM
Roland  is offline
Posts: 617  -  iTrader: (0)
Another cool trem-trick: Mushroomhead's "Solitaire unraveling" - Play an open E, drive the bar all the way down. Mute, let it come up, play a harmonic on the 3rd fret and drive the bar as far up as it will go. Very moody in the song!
As far as pinch harmonics go - I always find that the best all-out scream is above the neck-pickup coil-joint. Right in the middle.
bridge pickup, david lee roth, eddie van halen, neck pickup, pinch harmonics, steve lukather, steve vai, tremolo arm, van halen, zakk wylde
Vai at the Astoria question djpak Players, Bands, People, Music & Tours 22 04-27-2006 04:43 PM
Concert Review - Dave with Steve Vai - Atlanta 3/19/05 ADVJR Dave Weiner Official Forum Archive (SEE NEW LOCATION) 4 03-24-2005 09:43 PM
Hello Fellow Steve Vai Fanatics, Michael Lee Hill here frozenthought Players, Bands, People, Music & Tours 0 10-21-2004 01:54 PM
What speaker use Mr Steve Vai? Ced777 Gear and Equipment 9 06-20-2004 04:33 PM
Some cool Steve Vai stuff auctioned by Jemfest Carlo Jemfest Forum 4 02-29-2004 10:48 AM
