Players, People, Music and Tours
Guitar Lessons & Music Theory
Steve's whammy trill thing
Post any type of guitar or music lessons, theory and other learning methods.
08-28-2005, 05:46 AM
AMD1014
Posts: 178 - iTrader: (
Hi guys yeah i dont know how to explain it but you know how steve does that trill sound with the bar, how do you do guys do it?.
AMD1014
Find all posts by AMD1014
08-28-2005, 06:14 AM
mi2tom
Posts: 7,522 - iTrader: (
Re: Steve's whammy trill thing
Well I don't know just try to sound like him I mean using the bar
mi2tom
Visit mi2tom's homepage!
Find all posts by mi2tom
08-28-2005, 06:26 AM
Algiman
Posts: 2,552 - iTrader: (
Depress the bar about an inch, then let is snap back on it's own. That's all there is to it. Works better if you point the back backwards first, and the effect is dependant upon how the guitar is set up, but it will work on any floyd type trem.
Algiman
Find all posts by Algiman
08-28-2005, 09:57 AM
Shep
Posts: 542 - iTrader: (
i just pull it back ( or up ) and then just let go of it.or you can just tap it.that works to.
Shep
Find all posts by Shep
08-28-2005, 10:17 AM
fettouhi
Posts: 9,937 - iTrader: (
AMD1014
It's called the flutter effect.
Regards
André
fettouhi
Find all posts by fettouhi
08-28-2005, 11:53 AM
eelblack2
Posts: 865 - iTrader: (
As stated above its commonly called Flutter. Brad Gillis also uses the technique a lot. An easy way to execute it while holding your pick is to use your middle finger (the longest finger), and strike the very tip of the bar and let your finger pop/slide off the rounded end end of the bar after pressing it down. The tremelo with snap back into place and slightly overcompensate (go sharp, go flat, go sharp etc) - end thus you have that cool effect.
Lee
eelblack2
Find all posts by eelblack2
08-28-2005, 02:57 PM
guitarshredder7
Posts: 610 - iTrader: (
yeah it is a cool effect
guitarshredder7
Find all posts by guitarshredder7
08-28-2005, 06:28 PM
AMD1014
Ah the flutter effect hahah thanks guys ill practice it.
AMD1014
08-29-2005, 01:24 AM
guitarshredder7
yeah practice it
guitarshredder7
09-02-2005, 04:51 PM
Ekim
Posts: 1,483 - iTrader: (
Reviews: 4
Hey, maybe you should practice it!
Ekim
Find all posts by Ekim
09-02-2005, 05:45 PM
marianozz
Posts: 2,221 - iTrader: (
Yeah go practice it!
j/k...
I love the Flutter in the Petrucci's solo from "Under a glass moon"
marianozz
Find all posts by marianozz
09-02-2005, 06:04 PM
JJEMMER777
Posts: 8,374 - iTrader: (
Algiman
I agree. Much easier if the bar is back.
JJEMMER777
Find all posts by JJEMMER777
09-02-2005, 06:53 PM
timi_h
Posts: 1,104 - iTrader: (
marianozz
i love that solo! far better than most petrucci solos, got a structure!!
timi_h
Find all posts by timi_h
09-04-2005, 02:47 AM
Chris From Singapore.
Posts: 462 - iTrader: (
Make sure your
trem arm
is fitted tightly into the trem...lest you get a THUD instead of the desired flutter
Have fun!
Visit Chris From Singapore.'s homepage!
Find all posts by Chris From Singapore.
04-16-2006, 06:02 AM
Spider-Skot
Posts: 190 - iTrader: (
Old thread, but I don't care
I've had my RG370DX for about 2 years now, and I cannot get it to do that (flutter). I've tried old springs, springs at an angle (they're like this /|\ now) springs parallel. I even stored it in its case for days at a time with the bar on the guitar to try and stretch them out a bit, all to no avail. I could do it with my old '90 EX350 (with the old-school Floyd) and both of my old '91 RG550s (both with the first Lo-
Pro Edge
), but not my '03 RG370DX. Any suggestions??
Thanks
Spider-Skot
Visit Spider-Skot's homepage!
Find all posts by Spider-Skot
guitar body
pro edge
trem arm
what is the proper diameter and thread pitch for ibanez s whammy bar
digitech whammy what do you use it for?
Playing in front of a camera with lights on you is a different thing, 'Bet you can't play this, cos
how to use whammy bar yamaha pacifica
what is that thing on herman li finger
Where can I get the JEM unfloating block thing?
Ekim
Tech: Setup, Repairs and Mods
08:31 PM
Joe Satriani's squeally thing... - How?
foureyezonme
12:03 AM
Soldano rackmount amp thing... - what is this thing?
texshred777
Gear and Equipment
06:20 PM
Whammy pedal - Should I get the real thing?
YJM
Gear and Equipment
10:11 AM
The Satch harmonic run - Not the Satch scream thing
rikkbeatty
12:01 AM
10:29 PM
