<back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 06-20-2005, 06:08 AM
Ralph khoury  is offline
Posts: 451  -  iTrader: (0)
tap delay, how it works?
Hey folks, can anybody help me with tap delay, what is it? how does it work? thanks!
Old 06-20-2005, 08:38 AM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
Re: tap delay, how it works?
You tap your foot on a momentary footswitch in a regular tempo, and the delay repeats will match your rhythm.
Old 06-20-2005, 08:54 AM
so i set the rythm with my taps? how many times should i tap?
Old 06-20-2005, 10:46 AM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
enough so it can get a consistant feel for the rhythm - two or three taps, and any slight variations will become obvious. Four or five, and it should be tighter.
Old 06-20-2005, 10:51 AM
ok, thx for ur inputs guys!
Old 06-21-2005, 04:01 PM
bammbamm  is offline
Not quite right.
That is a tap/tempo delay.
If he has a tap delay, he may have a delay thet each 'tap' is one repeat.
You set the number of taps and can define the intervals between taps to give a reverse effect, or doppler shift feel. An algorithm is already set up in many cases.
You can get some cool sounding effects if you set the overall delay time short (1,2,5,10ms) and then alter the # of taps,(1-7) this can give you a slightly flanger on hold setting which can be great for lead tones.
Hope this helps.
Bamm
Old 06-22-2005, 08:31 PM
thx for ur tips bamm, that tap thing seems pretty interesting, i will start experimenting.
darren wilson
Boss DD20 Giga Delay vs........... EnigmaUV7 Gear and Equipment 15 08-22-2004 02:04 AM
Arion delay and phaser Ancestor Gear and Equipment 2 06-25-2003 04:38 PM
BOSS ME-33 patch switching delay - 0.5 sec delay when switch green tinted Gear and Equipment 2 03-07-2002 08:36 PM
Delay biz - Questions about delay effect units, help apprecc hermit Gear and Equipment 11 04-19-2001 12:44 PM
