Players, People, Music and Tours
Guitar Lessons & Music Theory
Tuner Help I Cant Make CENTZ of this and it HERTZ
Post any type of guitar or music lessons, theory and other learning methods.
04-03-2006, 11:26 PM
ibanezcollector
Posts: 3,205 - iTrader: (
29
Ok pardon my slight retarded-ness I cant seem to find any really good info
I need to know the followiing
what a 1/4 step flat would be in Centz and Hertz
what a 1/2 step flat would be in Centz and Hertz
thanks guys I can always count on you
Brett
ibanezcollector
Visit ibanezcollector's homepage!
Find all posts by ibanezcollector
04-04-2006, 09:51 AM
toneboy
Posts: 1,665 - iTrader: (
Re: Tuner Help I Cant Make CENTZ of this and it HERTZ
I can give you some info on the "Hertz" part of your question.
While I don't have a solid answer for you, I can tell you this. The frequency of the low A string is 110 hertz. If you up an octave (2nd fret on the G string), that A is 220 hertz. When you jump up another octave (5th fret high E string), that A is 440 hertz. So all of this means it's not going to be easy to determine what a 1/4 or 1/2 step lower in hertz is for a given note unless you have memorized the data. The Hertz measurement is logarithmic. As you go up in pitch, the number of hertz, or cycles, increases logarithmicly. I can't think of a better example than the first one I gave you.
What exactly are you trying to do? Knowing that info might help you to get a better answer to your question.
toneboy
Find all posts by toneboy
04-04-2006, 10:29 AM
toneboy
I just found this
chart
and it shows the hertz value for 12 octaves worth of notes.
Find the open A string on the chart (110 Hz). Go down the octave to the next E note and that's the open E string (82.4 Hz). To tune down a 1/2 step, the low E string would be 77.8 Hz for D#.
toneboy
how to make an evh 5150 replica guitar
how to make an LED fretboard
how do drop d on a tuner
"how to make" " gloss enamel"
how do them make the swirl jem guitr
08:25 AM
