<back   Jemsite > Players, People, Music and Tours > Guitar Lessons & Music Theory
Guitar Lessons & Music Theory Post any type of guitar or music lessons, theory and other learning methods.
Old 09-09-2002, 09:51 PM
eg  is offline
Posts: 259  -  iTrader: (0)
Unwanted ringing and string noises
I have problems getting a distinct and clear tone when I play using distortion. This mostly occurs when the gain is set real high.
I would like some advice on how to mute the unplayed strings so that they woudln't ring then they are not supposed to.
Old 09-09-2002, 09:54 PM
Two hands31  is offline
Posts: 4,989  -  iTrader: (0)
I've gotten real used to muting, and recently had to completely change my technique because putting my right palm on the strings between notes apparently creates FEEDBACK at high volume levels with my current setup. Don't know why...
Old 09-09-2002, 11:56 PM
Rich  is offline
Playing technique is pretty far out of my areas of expertise, but what the hell
Good muting is about as much an artform as good playing. Of course you can palm mute, but you have to do it without making noice itself. Slapping and rubbing your palm around on the strings creates lots of noise, so to me palm muting is very relaxed and just "touching" the strings [that's when I think I'm doing it right because I have a bad habit of digging in, which creats noise]. You also need to mute with the fretting fingers you're not using as much as possible, so you can throw your right hand in the air and pose. Why you always see that index finger laying across the strings as a muting barr behind where you're fretting. And depending on how low your action is the difference of muting as opposed to unwanted fretting of the barr is very small. But all unused fingers can be used for muting. Of course you can mute with the fingers you are fretting with too by how they touch the adjoining strings. Muting techniques need to be part of the way you play so it's not something you think about, you just do it. Unfortunately I keep finding myself having to mute noise, and if I got the noise at all, I wasn't accurately muting to begin with.
Old 09-10-2002, 04:52 AM
eg  is offline
Thats good advice...
Means I should try to mute with both right and left hands
Some of my problems also stem during vibratos and pull offs... where my finger brushes against the adjacent strings
This is esp true when playing the same fret sucessively on adjacent strings.
I tried to lift my fretting finger after the note duration but sometimes the notes come out sounding like staccatos.
I suppose I need more practice.
Any ground rules to achieve this from you guys?
palm mute, palm muting
