Players, People, Music and Tours
Guitar Lessons & Music Theory
What counts as being "In tune"?
Post any type of guitar or music lessons, theory and other learning methods.
04-04-2007, 12:35 PM
thedonutman
Posts: 112 - iTrader: (
I set up my RG yesterday(it was going horribly out of tune) So I lubed the knife edges. And since yesterday morning, I've been doing some serious whammy bar stuff. And a few of the strings a between 2-8 cents out. I can't really notice the difference(I used a tuner to check)
Is this good enough for most people? My musical ear isn't that great you see, so I can't really judge.
thedonutman
Find all posts by thedonutman
04-04-2007, 01:09 PM
Josh_P
Posts: 381 - iTrader: (
Re: What counts as being "In tune"?
It's either in tune or out, no middle ground with me. If you can't hear an 8 cent difference with your ear I would suggest running an inline tuner at all times.
Josh_P
Visit Josh_P's homepage!
Find all posts by Josh_P
04-04-2007, 01:23 PM
thedonutman
I can tell if 2 notes a different if I play them on their own. But In the context of a riff I can't really tell.
thedonutman
04-04-2007, 02:39 PM
Josh_P
Chords always helped me fine tune my ear at first. Now it's almost a curse
: v (
Josh_P
04-04-2007, 05:27 PM
shogun
Posts: 1,525 - iTrader: (
Josh_P
: v (
i am pretty close to having perfect pitch.. and i must say the bad thing about having good ears is u demand perfection when setting up a guitar.
shogun
Visit shogun's homepage!
Find all posts by shogun
04-05-2007, 01:04 AM
Dee
Posts: 8,514 - iTrader: (
Same here. I finally realized when an ex-girlfriend's door creaked and I said "that's a G#", then went over to the piano and it was dead on!
Anyways, I agree with Donutman -- when you're playing, the chances are you nor anyone else will hear a note that's out by a few cents.
Dee
Find all posts by Dee
04-05-2007, 07:45 PM
Rocker1
Posts: 209 - iTrader: (
shogun
Ha Ha you find it aswell when u set up a guitar
Rocker1
Find all posts by Rocker1
04-05-2007, 07:54 PM
newbieguitarmaker
Posts: 4,030 - iTrader: (
My ears are sensitive to tunings so the smallest difference annoys me, being perfectly on 440 is in tune for me and shogun you are right having perfect pitch and a good musical ear does make me demand perfection, i can thank my dad for passing on this skill
newbieguitarmaker
Find all posts by newbieguitarmaker
04-05-2007, 08:01 PM
S-man
Posts: 1,757 - iTrader: (
Guitars are inherently out of tune to a degree.
There is NO way your guitar will be completely in tune all the way up and down the fretboard on every string. It's all a compromise...
I try to find the middle ground.
S-man
Find all posts by S-man
04-05-2007, 08:05 PM
S-man
G and B are the worse offenders....it can be maddening.
That's why I just try to find the middle ground, stop being so critical and jam.
S-man
04-05-2007, 09:22 PM
Andelusion
Posts: 1,373 - iTrader: (
I only ever rush over to my tuner if I really notice that I'm going out of tune.
That is of course as well as tuning up my guitar as soon as I pick it up each day, imo you shouldn't play your guitar if it's out of tune, as it's undoing the accuracy of your finger-ear coordination
Overtime your ear will probably become more sensitive to suble discrepencies in intonation, I know that 4-5 years ago I would have noticed when I was out of tune, but if someone had played a chord, I wouldn't be able to tell you which string/degree was out of tune, now my ear seems to pick it out straight away.
Andelusion
Find all posts by Andelusion
04-06-2007, 06:59 AM
thedonutman
What I find worrying since I've got my tuner is that I can get about 10-20 cents of tuning variation just by resting my hand on the bridge or turning my guitar so it faces the ground or ceiling.
And what is even more worrying is that I never really noticed it until I checked with a tuner.
thedonutman
04-06-2007, 11:51 AM
buddroyce
Posts: 1,914 - iTrader: (
thedonutman
When you play out with a band and sound off, then you're out of tune. Otherwise.. I wouldn't stress about it.. Otherwise that's why you hire goons like me to work as guitar techs.
buddroyce
Visit buddroyce's homepage!
Find all posts by buddroyce
04-12-2007, 10:33 AM
CrossingStar
Posts: 1,046 - iTrader: (
A tuner might tell you a string is ON PITCH but it depends on what you like to hear. Tuning open strings to a tuner, and I have a Peterson mind you, can get you there for a base reference but I lower the G string a bit by ear and the B string I lower a bit, too. When I recheck the G string especially is horribly flat according to the VS-1 but sounds better to me - in relation to the other strings - than when it was telling me it was in tune. If I needed to open G string to be in tune on it's own then I would go by what the Peterson reads. But tuning a guitar is never perfect so you have to decide what sounds best and what amount of dissonance you can live with.
CrossingStar
Find all posts by CrossingStar
04-12-2007, 10:38 AM
S-man
+1
S-man
buzz feiten
buzz feiten tuning system
guitar tech
tuning system
how to tune lo-trs
how to tune a jem jr
what tune does mushroomhead use?
when using tremolo bar tune is bad
WHAT KIND OF GUGE DO I NEED TO TUNE TO DROP A?
"In my dreams with you" backing track?
Davey
11:49 AM
07:39 PM
