<back   Jemsite > Players, People, Music and Tours > Multimedia: Music, Pictures & Sounds
Multimedia: Music, Pictures & Sounds share links to MP3s, JPGs, Videos, Youtube or other music or multimedia (no bootleg or illegal file sharing please).
Old 12-04-2004, 09:09 AM
Azrael  is offline
Posts: 403  -  iTrader: (0)
Audio out of sync in Cubase VST
I'm running Cubase VST under Mac OS 9.2 and my audio gets out of sync. It doesn't always happen but it happens alot. I have an I-mac DV 400mhz with 256mb ram so that should be enough to record more than 4 tracks at once for sure(currently 5 but going to use 6). I tried disabling every effect that I had in Cubase but I still have the problem. When I record it it sounds ok through my speakers (I monitor with Cubase) but when I play it back the audio is out of sync.
Anyone else happened to have had this problem?
Thanks in advance,
Sander
Old 12-04-2004, 01:20 PM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
It's called "lag" or "latency". Your machine is probably about as minimal as Cubase can support for more than a couple of tracks of audio. If you're recording using the analog input, there's a delay involved in digitizing that sound.
You might consider investing in a USB audio interface which would probably speed up the analog-to-digital conversion and possibly lower your latency. A dedicated 7200RPM FireWire hard drive for your audio files would also help, as would more than 256 MB of RAM.
The older iMacs are great general-purpose machines, but don't really excel at pumping a lot of data through the RAM, hard drive, etc.
Old 12-04-2004, 01:27 PM
Azrael  is offline
Ok.....thanks for all the info then. I'm getting a new secondhand windows computer soon with about 800/1000mhz(not sure what it was) so maybe I'll be able to record some more tracks then. It could indeed be that my computer is maxing out. I checked the CPU meter while recording and most of the time it is around 40% but sometimes the light next to it gets red and that's means it overloads. Just my computer then.....oh well.....I'll wait for my new one.
Old 12-04-2004, 04:04 PM
As i mentioned, it's not just the raw CPU speed. You need a dedicated digital interface, a fast, hard drive that's used ONLY for digital audio and loads of RAM. If you don't have either of those things in your new computer, you won't get any better results.
audio interface
