<back   Jemsite > Players, People, Music and Tours > Multimedia: Music, Pictures & Sounds
Multimedia: Music, Pictures & Sounds share links to MP3s, JPGs, Videos, Youtube or other music or multimedia (no bootleg or illegal file sharing please).
Old 10-11-2003, 06:53 PM
hanban  is offline
Posts: 280  -  iTrader: (0)
Check out my cover for vai's "for the love of god"
Hey..
a cover for this song is getting real old i know
but i figured any vai fan should rec this one at some point.
i used my new RG-2820 , for some reason this one sounded better than my 7vwh in this tune.
save as:
http://www.digitalsoundplanet.com/Me..._000012549.mp3
let me know what you think please. specifically sound wise, because i used a new effect i made for this tune..
greetingz
David
Old 10-11-2003, 07:05 PM
keithb  is offline
Posts: 163  -  iTrader: (1)
Good job. Very close to the original tone, to my ears.
About as close as I've heard yet
What was your setup for this?
Old 10-11-2003, 07:10 PM
hanban  is offline
Thanks
im using my new podxt plugged direct
Old 10-11-2003, 07:22 PM
Gresh  is offline
Posts: 1,416  -  iTrader: (10)
Sounds fantastic, great work and basically a dead on recreation of the original. Impressive to say the very least.
Eddie Von Stef  is offline
Posts: 7  -  iTrader: (0)
Wow-some!
Nice job dude!
The tone is killer! I thought it sounded exactly like the cd. Could you tell me what kind of equipment you are using, cause I really like the way it sounds. I also can't believe you can play that song. Good for you man!
Old 10-11-2003, 07:26 PM
hanban  is offline
thanks for checking it out guys! appreciat it.
eddie, basically all you need it a podxt and a floorboard so u can operate a decent wah.
you dont even need an amp
for some reason the guitar sounds alot better when you listeb to it with headphones , try it out.
Old 10-11-2003, 07:39 PM
keithb  is offline
Now I need to ask: what patch/settings did you use? It sounds soooo close
Old 10-11-2003, 08:03 PM
Ralph khoury  is offline
Posts: 451  -  iTrader: (0)
Cool work! and the Pod xt rocks! keep up the good work hanban!
Old 10-11-2003, 08:33 PM
hanban  is offline
keithb, i didnt use a patch.
made this one from scrap
but i can covert it to a patch file if you want
David
Old 10-11-2003, 08:47 PM
hanban  is offline
here is another vai'ish effect i made
i played a small sample so you can check it out
http://www.digitalsoundplanet.com/Me..._000011864.mp3
Old 10-12-2003, 01:26 AM
davester1234  is offline
Posts: 1,221  -  iTrader: (0)
what type of mic do you use to record?
Old 10-12-2003, 01:39 AM
keithb  is offline
David
Actually, I don't have a POD, but I'd be interested in the settings/models/etc that you used. Maybe I can get something close with my gear (I hope ).
Old 10-12-2003, 02:44 AM
This is kind of a general question I had about the POD. How exactly does it work? I realize that you can plug it direct into your computer, and then use recording software to record songs. But can you also plug it into your amp, kind of like you would with a stomp box? And how much of a difference would that make in the sound? I'm asking because I liked the sound that Hanban was getting so much that I checked out the Line 6 website, and am considering getting one of these suckers. But I'm more interested in using it in a live setting rather than recording with it. If someone could fill me in that would be grand. And Hanban, you should definately post those settings you used for FTLOG.
Old 10-12-2003, 05:26 AM
hanban  is offline
davester, i used SM-57 condenser - on axis position.
placed it about 30cm from the amp.
eddie, ofcourse you can plug your podXT into an amp. infact, i plug it into my fender twin reverb and the sound is great (ofcourse an all tube amp helps )
in the pod, you can choose whatever you want the pod to "work" with.
you have a "front of combo" setting, incase you want to plug it to your amp, you have studio and direct options.
ofcourse when you plug it direct, the pod uses its amp simulation so recording to your comp wont sound "direct", it will sound like a pro amp and mic were used. when you plug to the amp, the pod remodels all its effects so they will sound good on an actuall open-back amp.
you can use it live with your amps. just dont forget to order the floorborad with it, because when you play live you need fast switching , + the board gives you wah and volume control.
+ you have a whole bunch of pedal models to choose from , such as big muff Pi, MXR compressor, RAT, fuzz, some electro harmonix pedals and what not.
as for settings, ill post it in an hour or so, im not near the pod atm.
Old 10-12-2003, 05:33 AM
Anton  is offline
Posts: 740  -  iTrader: (0)
Nice cover fella , what pups are in your RG ?
backing track, electro harmonix, fender twin, fender twin reverb, stomp box, tube amp, twin reverb
