Players, People, Music and Tours
Players, Bands, People, Music & Tours
Vai-Tunes - why no 24bit audio?
Post news about bands (including yours!), or talk about other music, CDs, DVDs, videos, tours or appearances.
12-08-2004, 04:21 AM
microdmitry
Posts: 1,687 - iTrader: (
Hopefully someone from Vai.com is reading this. As far as I know, AAC allows one to compress 24 bit audio. So I was wondering if there's a particular reason why mr. Vai doesn't sell 24 bit versions of his tunes in Vai Tunes online store.
I don't know about anyone else, but I'm really hoping to buy all Steve's records all over again, but this time remastered in pristine 24 bit / 192 KHz.
Wouldn't it be cool if something like this was available today? I'd gladly pay extra.
microdmitry
Find all posts by microdmitry
12-08-2004, 05:08 AM
Jeroenn
Posts: 873 - iTrader: (
Re: Vai-Tunes - why no 24bit audio?
microdmitry
You know vai.com has a forum too eh?
Cool that you like the store! Spread the word. The more people we get that buy stuff there, the more files we pump in there.
Anyway, all the files are encoded at 256k. I suspect it to be the optimimal size/sound ratio. The higher the soundquality, the size of the files grow substantially.
Anyway, we'd love to hear your feedback on the tunes, right here:
http://www.vai.com/phpBB2/viewtopic....&start=285
Thanks,
Jeroen
vai.com
Jeroenn
Visit Jeroenn's homepage!
Find all posts by Jeroenn
12-08-2004, 08:17 AM
JESTER700
Posts: 2,234 - iTrader: (
microdmitry
Lossy compression has different rules than PCM. Assuming the 256k rate is right, you will get better sound using all that to store the 16 bit file. Remember, 24/96 uses 5x the data that 16/44 uses.
JESTER700
Find all posts by JESTER700
12-08-2004, 01:23 PM
microdmitry
Yup. I have broadband, so I'm quite comfortable downloading a file that's five times larger. Besides, I think high bit depth/bit rate files will have better compression ratio because the amount of additional information is not that substantial. But yeah, they'll be bigger anyway.
microdmitry
12-08-2004, 05:09 PM
Drew
Posts: 4,538 - iTrader: (
Well, that's the thing... there will be 192 kilobytes of audio data per second present in a 192kbs mp3 no matter WHAT the sampling rate is- Sure, you could encode with a sampling rate of 24Hz, but that means that the codec would have to reject that much more information- it doesn't make sense to up the sampling rate that high unless you're encoding at a much higher frequency. If you're trying to squeeze five times the information into a codec that only has room for a given amount of data per second, all you'll get is five times the loss, which translates to more digital garbling.
at least, that's my understanding...
-D
Drew
Visit Drew's homepage!
Find all posts by Drew
how to unmute your audio
do I need special cable for digital audio?
how to replace tubes audio pre-amp
how to strint guitar with sperzel locking tunes
how to record audio from guitar
04:48 PM
