I'm selling a 1989 Ibanez
RG 570 Body and Neck made in Japan. Most of the parts have been used fixing up other guitars I own. The neck is stamped 550R which I think was very common in those days. It is the original super thin
Wizard neck. The body is marked 570. I think the color is Jewel Blue, but I'm not 100%. The headstock is painted to match. The neck was professionally refretted about 1 year ago with jumbo wire and shows very little wear. The body and neck both have some paint chips from normal use. The body also has 2 small holes behind the bridge pickup where I used to have a Roland pickup mounted. There is also a small hole above the jack cavity where the wire came through for that pickup. The input jack area was also drilled to fit a regular jack and plate instead of the barrel. This has the original square heel neck joint and I do have the plate and screws for it. Would be great to restore or for a custom project. I would like $175 shipped anywhere in the U.S. Here are some pics.
http://i56.photobucket.com/albums/g1...Ibanez5701.jpg
http://i56.photobucket.com/albums/g1...Ibanez5704.jpg
http://i56.photobucket.com/albums/g1...Ibanez5702.jpg
http://i56.photobucket.com/albums/g1...Ibanez5703.jpg
http://i56.photobucket.com/albums/g1...Ibanez5705.jpg
http://i56.photobucket.com/albums/g1...Ibanez5706.jpg
http://i56.photobucket.com/albums/g1...Ibanez5707.jpg
http://i56.photobucket.com/albums/g1...Ibanez5708.jpg
http://i56.photobucket.com/albums/g1...Ibanez5709.jpg
