<back   Jemsite > Buy, Sell or Trade > Classified Ads: Guitars and Gear
Classified Ads: Guitars and Gear Guitar and Gear Classified ads. List your items for sale and/ or trade List items you Want to buy. This topic is heavily moderated and is not for listing JEM/Universe guitars or links to auctions.
Old 07-12-2007, 01:32 PM
rikkbeatty  is offline
Ibanez endorsed
Posts: 1,218  -  iTrader: (6)
FS: BOSS DR-880 DRUM MACHINE
Hey folks,
I am helping a buddy sell some gear. I just sold his custom DNA like guitar to Jemaholic. What we have here is a Boss DR-880 drum machine for sale. Its in perfect working order and condition. It comes with everything you get when its brand new (including the box). $325 + $10.00 shipping
http://www.jasonrpcrabbe.com/files/Drum_Machine_All.JPG
You can get microscopic with the DR-880, but you also have the option
of taking the simple route with its three "EZ Compose" buttons, which
allow original patterns to be constructed without note-by-note
programming hassles. Patterns can be taken deeper with the "Groove
Modify" feature, where various groove and triplet feels can be applied.
Ghost notes and fills can also be added automatically. Guitar and bass
players can join the action by plugging directly to the DR-880?s
guitar/bass input jack, and playing through the built-in COSM drive/amp
models and multi-effects.
Features
Innovative "EZ Compose" feature for quick, hassle-free programming
440 world-class drum and percussion sounds, 40 bass sounds with
COSM bass-amp models
Guitar/bass input, multi-effects, COSM amp models
3 independent insert effects (EQ and compression), TSC (Total Sound
Control) featuring 3-band EQ and high-quality ambience
1,000 patterns (500 preset, 500 user); easily add fills, ghost notes,
chord progressions, and more
20 velocity-sensitive pads
Four assignable footswitch and expression-pedal inputs
Individual outputs, digital out, USB port
World-Class Sounds
A remarkable new collection of top-quality, custom sounds was created
for the DR-880. But we didn?t stop there; some of the most famous
sounds from our renowned SRX library were added to the DR-880?s
sound-set, as well as electric and synth bass sounds. From rich,
sparkling studio drums and deep-dish electronic kits to standard and
exotic percussion instruments, a world of rhythm and groove is at your
fingertips.
Direct Guitar/Bass Input
Guitar and bass players can join the action by plugging directly into the
DR-880?s Guitar/Bass Input jack. Guitarists can play through the built-in
COSM Drive/Amp models, and multi-effects such as
chorus/flanger/phaser, delay, and reverb. For acoustic guitar, the DR-
880 offers an Acoustic Processor, chorus, and reverb. For bass players,
the compressor/limiter, chorus/flanger/phaser, delay, and COSM� bass
amp models will help you cook up extra-tasty bass lines.
EZ Compose
of taking the simple route with its three EZ Compose buttons on the front
panel, which allow original patterns to be constructed without note-by-
note programming hassles. Using the Pattern mode, you can select and
combine pre-programmed phrase combinations to create new patterns.
Press the Chord Progression button to select chord-progression
templates. With the Fill-In button, you can select phrases from the Fill-In
library, and insert them into the pattern. The library contains a variety of
phrases, ranging from simple fills to bombastic breaks.
Connectivity
Play through headphones or route your signal from the DR-880 directly
to your choice of recording input or amplification, including outboard
guitar amps. Quick output adjustments can be made in the Output
Select mode to facilitate proper connection to the outside world. Two
individual Outs allow independent output of backing tracks and guitars,
or independent output of kick and snare. The DR-880 has two stereo
footswitch/controller inputs; a maximum of four footswitches can be
connected using stereo 1/4" cables (sold separately). One of the
footswitch/controller jacks supports expression pedal input, so you can
connect an EV-5 (sold separately) to control guitar volume, or play wah
effects. The DR-880 also has a S/PDIF digital out and a USB port for
MIDI interfacing and SMF Data import.
Groove Modify
Take your grooves even deeper with the Groove Modify feature, which
applies various groove and triplet feels to your patterns. Simply select
the templates that are included, and inject realistic feels to static
patterns. Ghost notes can also be added automatically by selecting the
ghost-note phrases that are preset in the DR-880.
Technical Info
Maximum Polyphony - 32
*Depending on the bass sounds selected, maximum polyphony may be
lower
Instruments - Drums: 440, Bass: 40
Kits - Preset: 100, User: 100
Rhythm Patterns - Preset: 500, User: 500
Songs - User: 100
Maximum Note Storage - approx. 30,000 notes
Resolution - Per quarter note: 96
Tempo - Quarter note: 20 ? 260 bpm
Pads - 20 with velocity sensitive
Display - Custom LCD (with backlight)
Connectors -
Rear: Master Out L(Mono), R (1/4" phone type), Master Out L, R (RCA
pin type), Individual Out A, B (1/4" phone type), Digital Out (coaxial),
USB, CTL 1/2 jack(1/4" TRS phone type), CTL 3/4(EXP Pedal) jack (1/4"
TRS phone type), MIDI In, Out, AC Adaptor jack
Front: Phones (stereo 1/4" phone type), Guitar/Bass Input (1/4" phone
type)
Power Supply - AC Adaptor (BOSS BRC series)
Current Draw - 600 mA (Max)
Accessories - AC Adaptor (BRC series), Owner?s Manual, DR-880
Driver CD-ROM
Options - Foot Switch: FS-5U, FS-6, Expression Pedal: EV-5,
Connection Cable: PCS-31 (Roland)
Dimensions (W x D x H) - 273 x 242 x 72 mm (10 3/4 x 9 9/16 x 2 7/8 in)
Weight - 1.4 kg (3 lbs. 2 oz.)
acoustic guitar, backing track, chord progression, chord progressions, expression pedal, foot switch
[IMG] code is Off
Drum Machine and Loops Recommendation Batchimp RG Recording Studio 20 02-24-2008 06:24 PM
FS: BOSS DR-880 drum machine rikkbeatty Classified Ads: Guitars and Gear 1 08-31-2006 12:22 PM
I made a MIDI drum machine for linux Ferrous Lepidoptera Recording Studio 2 07-17-2005 12:23 AM
Drum Machines....... - Yamaha or Boss? cowcowcow Gear and Equipment 7 03-25-2001 11:19 PM
Looking for good Drum Machine cowcowcow Gear and Equipment 6 01-26-2001 02:23 PM
