http://i5.photobucket.com/albums/y17...ur700front.jpg
http://i5.photobucket.com/albums/y17...our700back.jpg
Yes that's right, a whole 700 ****ing watts! The reason I'm selling is not just because I need the extra money right now but because that wattage is more than I'll ever need for my 300watt cab and so I wanna downgrade either way.
Features:
700W into 4 ohms (4-ohm minimum load)
Pre- and post-gain controls
Bright and and low-cut switches
Contour control for advanced signal shaping
Active high and low shelving controls
Hi boost, low cut
9-band constant-Q graphic equalizer with bypass switch
Analog octave divider with level control
and footswitchable bypass
Post-EQ effects loop
Buffered tuner send jack
DI XLR output with fail-safe phantom power backup capability
input jacks for high and low output bases
Rear-mounted auxiliary input jack
In immaculate condition (no scratches or anything), never used for gigging, only in my room on my own a coupla times! Excuse the dust, that's how little I use it!
£280 (or best offer), obviously includes the AC adaptor, but not the rackmount.
Pick up only (from Leeds)
