For sale is my modified
Vox Satchurator.
This pedal has been modded by Pedalmods UK (very highly rated and well reviewed) to include 2 toggle switches.
The first changes the nature of the gain to a thicker, more open type of aggressive crunch with added volume. This setting is NUTS, really cuts through a mix and sounds more like Satch to me than the stock pedal.
The second switch adds a slight mid boost. Very subtle, but again helps in getting your sound to stand out in a mix.
With both switches OFF, it reverts to the stock pedal, but with a smoother, less fizzy sound than the stock (due an upgrade of smoothing caps).
Pedal sounds absolutely killer!
If you check out
www.pedalmods.com and scroll down to the bottom of the home page, the Satchurator they are talking about (and that is photographed) is mine!!
The pedal is in good condition, (it has a couple of small paint chips through normal usage - nothing serious) .
Looking for £95 shipped to anywhere in the UK, or you can collect from SL2 way.
Thanks!
Sukh
