2 amps are better than one ? - Jemsite
post #1 of 9 (permalink) Old 12-16-2012, 05:38 PM Thread Starter
Right just because im a little bored and been watching a joe bonamassa dvd, got to thinking why have one amp when you can have two, ...also happens that ive seen a rather tasty amp id like to buy....
but my question is does this rig diagram make sense ? are there any problems i might have over looked etc.... and input would be great
Toadster is offline
post #2 of 9 (permalink) Old 12-16-2012, 07:40 PM
Reviews: 98
Re: 2 amps are better than one ?
Run the modulation effects through the respective amp's effects loop.
AlaskaBat is offline
post #3 of 9 (permalink) Old 12-16-2012, 08:26 PM
Reviews: 15
This ^^^^^ although why not run it as a stereo setup instead.
silverctr is offline
post #4 of 9 (permalink) Old 12-16-2012, 08:30 PM
Reviews: 98
I was thinking that too, but running them separately gives more tonal flavors.
post #5 of 9 (permalink) Old 12-16-2012, 09:20 PM
Steve Vai does something like this:
http://www.ibanez.com/steves_rig
peterjbrown96 is offline
post #6 of 9 (permalink) Old 12-17-2012, 12:23 PM Thread Starter
thanks for the replys guys and yea would probly like to run the effects through the effects loop unfortunately the amp im using doesnt have one lol....
only other thing would the delay pedal work correctly after the flanger/ before the distortion ?
Toadster is offline
post #7 of 9 (permalink) Old 12-17-2012, 12:25 PM Thread Starter
and wow !!! that might be outta my budget lol !!! a man can dream tho !!
Toadster is offline
post #8 of 9 (permalink) Old 12-17-2012, 07:07 PM
after the flanger and before the distortion...
in short yeah it would work, but it may not be the best.
I've found it's best to put delay at/near the very end of your effects loop if you'r looking for a more natural sound; it could sound somewhat artificial otherwise.
I've found that on a really gainy channel, however, this particular arrangement causes (on my particular amp) a drop in distortion on the delayed material rather than volume. this will depend on whether you have a 'gain' box or a 'distortion' box; i wouldn't reccomend it with the latter,
Don't take my word for it though. GET OUT THERE AND TRY IT!!!
post #9 of 9 (permalink) Old 12-17-2012, 07:42 PM
Reviews: 98
If you're handy with a soldering iron--you can make a pedal loop switcher.
Human Verification
Blackstar Amps unveil HT-5 Amps at MusikMesse Milo Gear and Equipment 5 04-06-2011 09:57 PM
Need advice - rack mount amps -normal amps ? Jaden Gear and Equipment 7 10-20-2008 07:40 AM
Car Audio Amps vs. Guitar Amps Jeff Gear and Equipment 8 09-01-2003 07:47 AM
Can someone explain to me power amps and pre amps? BrianH Gear and Equipment 12 06-27-2002 11:40 AM
Amps, amps and more amps... - Suggestions...there are too ma carlos seo Gear and Equipment 4 05-17-2001 01:53 PM
