Gear and Equipment
2x12 Cabinet
Gear and Equipment
05-10-2009, 12:24 PM
nsabino
Posts: 463 - iTrader: (
2x12 Cabinet
Hi, I'm interested in getting a reasonably priced and good sounding 2x12 cabinet. What do you guys suggest?
Thanks, regards
Nelson
nsabino
Find all posts by nsabino
05-10-2009, 12:39 PM
toshiro
Posts: 1,812 - iTrader: (
Re: 2x12 Cabinet
In the US? Avatarspeakers.com. The Vintage 2-12 is killer.
toshiro
Visit toshiro's homepage!
Find all posts by toshiro
05-10-2009, 02:30 PM
skins345669
Posts: 835 - iTrader: (
Re: 2x12 Cabinet
In europe, Framus cabs are awesome.
skins345669
Find all posts by skins345669
05-10-2009, 04:19 PM
Silverburst
Posts: 488 - iTrader: (
Re: 2x12 Cabinet
skins345669
I was looking into getting a decent but affordable 2x12 as well.
Skins, do you have personal experience with Framus cabs ? The V30 ones are really affordable, but it's hard to find decent comparative info about them, and I always have the feeling, when I'm reading reviews about them, I'm reading stuff written by starters
Silverburst
Find all posts by Silverburst
05-10-2009, 05:44 PM
skins345669
Re: 2x12 Cabinet
I have a closed back 2x12 with V30s and it's brilliant. Gives my amp so much more definition and a more articulate top compared to anything else I've tried, and with 100 watts pushing it, it gets LOUD (as you'd expect). You can also take off the back and get an open back sound too, which I haven't got round to trying. If you're interested, I've got the FR 212 CS CB.
skins345669
05-10-2009, 05:50 PM
Silverburst
Re: 2x12 Cabinet
Skins, that's the one with V30's right ? exactly the one I'm looking at. Could you elaborate a bit more plz ?
What amp do you use ?
What's you main genre ?
What other cabs did you compare it to ?
Nsabino, if I'm hijacking your thread here, give me a kick, but I thought this would be relevant for you as well
Silverburst
05-10-2009, 05:56 PM
nsabino
Re: 2x12 Cabinet
pmike
No problem man... you're just helpingme out...
Let me know if you have a chance to try out one of those Framus'.
Regards,
Nelson
nsabino
05-10-2009, 06:19 PM
skins345669
Re: 2x12 Cabinet
My amp... well... here goes...
Peavey Supreme XL
*prepares for onslaught of abuse*
My main genre is... Ummm... well I play a fair amount of classic rock, for which the pronounced treble and mids are great, same with punk stuff. As far as the technical stuff goes, I can get a pretty good Satch tone, but not so much Vai. Amp's not smooth enough.
Other cabs I've tried include the Peavy 4x12 I bought the head with, with Blue Marvels. Sounds very bassy/muddy to my ear. Same sort of thing in another cab loaded with Celestion G12Hs, although not nearly as much. The V12s have a definite brightness to them, but without being harsh (I have my EQ about 6 for bass, 10 for mids and 8 for treble on pretty much all channels), which probably comes from them being quite upper mids heavy compared to other speakers.
I reallllly want to try a JSX through my cab 'cause when I played it in the shop it sounded dull and my first thoughts were, "this needs some V30s to brighten it up".
06:25 PM
skins345669
05-11-2009, 01:53 PM
nsabino
Re: 2x12 Cabinet
Hi, thanks for the info guys, but I have to add something I forgot to mention. I'll be using a Roland 80x through this cabinet and I've heard that it's best to get more of a neutral sounding speaker for modelling amps. Is this a fact or would I still benefit from a specially voiced type of speaker like a Celestion Vintage 30?
Thanks, regards
Nelson
nsabino
05-11-2009, 02:17 PM
skins345669
Re: 2x12 Cabinet
I'd say it's totally subjective, see what you like.
skins345669
05-11-2009, 04:04 PM
Silverburst
Re: 2x12 Cabinet
if you have a modeling amp that has cab sims you'd want to use, you're better of with a FlatRangeFlatReponse cab. Maybe it's a good idea to check out some Roland forum about this as well.
Thanks for the Framus insight Skins
Silverburst
05-11-2009, 04:15 PM
skins345669
Re: 2x12 Cabinet
pmike
Glad I could help
skins345669
05-12-2009, 06:10 AM
nsabino
Re: 2x12 Cabinet
Thanks alot guys,
Regards,
Nelson
nsabino
06-14-2009, 07:20 PM
Guitarist-Jonny
Posts: 240 - iTrader: (
Reviews: 20
Re: 2x12 Cabinet
I just made my own 2x12. Got the 'frame' off a friend (about an inch thick chipboard or something) for almost nothing (he just got me to donate to charity). Mount ur stuff in it (including your speaker of choice) and your ready to go, not forgetting my newly built 2x12 is the most compact I've seen to date.
It was alot of fun to build, and now it has more sentiment than buying a new one, and saved me ALOT of money
Regards
Jon
Guitarist-Jonny
Visit Guitarist-Jonny's homepage!
Find all posts by Guitarist-Jonny
06-14-2009, 08:52 PM
lynchfan6
Posts: 192 - iTrader: (
Re: 2x12 Cabinet
Look for an old , used ADA 212 cab! I have one for when I don't feel like lugging my 412 around (which is most of the time). I think I bought mine used for like $160. Speakers are subjective, as I immediately replaced the Celestions in it with Eminence Legends for use with my SLO . But if you are looking for a well made, good sounding cab....can't go wrong with an old ADA split stack.
lynchfan6
Find all posts by lynchfan6
how to wire my speaker cabinet
what speakers does curt Mitchell use in his Marshall cabinet
how to build a speaker cabinet
4x12 0 2x12?
higher ohm cabinet with lower ohm amplifier?
WTB : 2x12 Speaker Cabinet
sweetnsour30
02:08 PM
Which 2x12 cabinet for a Peavey JSX
SimpleMind
Gear and Equipment
10:53 PM
Can anyone recommend me a 2x12 cabinet?
Dragon Slayer J
Gear and Equipment
12:32 PM
WTB: 2x12 Cabinet w V30s
Morbid
10:05 PM
2x12 cabinet comparisons
windows2thesoul
Gear and Equipment
02:10 PM
05:23 PM
