Gear and Equipment
450-550 Tube Combo Reccomendations
Gear and Equipment
08-06-2005, 09:35 PM
Kontalonis
Posts: 1,006 - iTrader: (
Hi, i have a birthday coming up and i was looking at getting myself a new
tube combo
The Carvin Nomad struck me with it's vintage looks and Celestion V30 speakers.
Any opinions on this amp? Any others i need to know about. I prefer celestion speakers and definitely want a
tube amp
Kontalonis
Find all posts by Kontalonis
08-06-2005, 09:49 PM
ScottB
Posts: 2,208 - iTrader: (
Re: 450-550 Tube Combo Reccomendations
Peavey Classic
30 (1x12) or Classic 50 (2x12). Check your local Peavey dealer for close-out deals on last years models. They upgraded the cosmetics for summer NAMM, but the older models have a much better (IMHO) appearance.
ScottB
Visit ScottB's homepage!
Find all posts by ScottB
08-06-2005, 10:20 PM
Kontalonis
Hmmmmmmmm i also have an old marshall i am thinking about restoring. It needs a couple of pots replaced but i have no idea what kind to get. It is a Marshall Master Lead Combo. I might just get it fixed up.
Kontalonis
08-06-2005, 10:39 PM
bonehead189
Posts: 537 - iTrader: (
Fixer-uper's always save money, and eliminate the hard decision of "which combo". I'd fix up the Marshall too!
bonehead189
Visit bonehead189's homepage!
Find all posts by bonehead189
08-06-2005, 10:47 PM
Kontalonis
Well i am at a bit of a delima. It has 4 solid shaft pots that work fine. Then it has one split shaft pot that also works but i doubt is factory (bass pot). And then the master volume is a solid pot with a little flat spot on one side. The nut is stuck on the inside of the amp which means the pot can be pushed in. What should i do to get this amp back to factory? Any amp gurus? I have no idea which pots are factory. :-(
Kontalonis
08-07-2005, 01:48 AM
Gex
Posts: 962 - iTrader: (
Any good tech should be able to jump in there and replace the pots in just a few minutes, real quick.
Gex
Find all posts by Gex
08-07-2005, 10:21 AM
ScottB
If it's 10+ years or older, have the tech replace the filter caps as well as the defective pots. New caps will breathe new life and sparkle into your old Marshall. A new set of JJ EL34 power tubes would't hurt either.
ScottB
08-07-2005, 10:31 AM
Kontalonis
Thanks for all the quick replies. I am going to see about taking it to someone. Thanks a bunch guys!
Kontalonis
08-07-2005, 01:01 PM
rgr
Posts: 1,791 - iTrader: (
Check out the
Peavey Valve King
, all tube, I think the combo is right around $400.
rgr
Find all posts by rgr
peavey classic
peavey valve king
tube amp
tube combo
valve king
how to turn on tube amp
how to set up a tube screamer
5150 combo tubes bad?
how to tell when preamp tube goes bad
What is the best low wattage tube amp
Carvin Legacy 100W combo Tube Replacement
Hiketsu
Tech: Setup, Repairs and Mods
07:39 PM
3-Channel Tube Combo
LennyNero
Gear and Equipment
12:07 PM
amp search - tube combo
johank
Gear and Equipment
01:40 PM
Good cheap tube combo amp? - Is it possible?
toddw7
Gear and Equipment
02:31 AM
12:16 AM
