Old 12-03-2006, 10:57 PM
Darin  is offline
Posts: 2,459  -  iTrader: (2)
Re: 80 watt 1x12 combo..loud enough?
Your amp will be miked on stage. And in the monitors. Alot of pro's use 1x12's. More than you'd think. It's plenty. Think of how loud a singer sings and his voice is miked. Your amp will be louder than that. If you use a pa at rehersal, mike it there too. So everyone can hear you. Just don't kill them with the volume.
Old 12-05-2006, 04:34 AM
Edwood  is offline
Posts: 106  -  iTrader: (0)
I've got a Peavey KB100... just like Lefty Robb said... no bueno for guitars. I use it for the few songs I play on bass. Sounds good for that, but then the 15" speaker blew... dropped in an old one from a Seymour Duncan cab that was getting moldy... and DAMN! it thumps nicely, now! [much bigger magnet... total weight of the KB100 went from 71 lbs to 93 lbs after the switch.]
Use a 50 watt SS Hughes & Kettner Edition Silver 1x12 Celestion, for [small] gigs. The loudest I've had to take it in my constant volume wars with the dumbazz rhythm guitarist is about 7. I usually park the clean channel around 4-5.
The efficiency of the speaker also determines how one 60 watt amp will sound louder than another 60 watt amp. [My KB100 is louder, at the same setting, after the swap.]
Last edited by Edwood; 12-08-2006 at 01:44 AM. Reason: orig. verbiage was unintentionally x-rated, LMFAO!
Old 12-06-2006, 05:51 AM
pera_a777  is offline
Posts: 406  -  iTrader: (0)
Thanks guys..
IN the meantime, i have tried the upper mentioned Roland dac 80d..with a 1x12..and, although it looks very naive and small, it is incredebly loud and punchy..really!
but, at very high volumes, on clean setting, the speaker would just start rattling when i use the 7th string..and although this was only at very very high volume, i couldnt take it because of that..
but i was very suprised how good amp it is..and even a dist. is pretty much useful!
BUt, whats important, i have concluded that 80w is way enough for my needs!
and kb100 i was looking is no longer an option, cauze arssehole seller raised price.twice..! from 130, it went to , current, 220 euros!!!
And one more thing..after playing this Roland, considering it is a good amp, and in a really good condition really, i have concluded that i probably need something bigger..i mean probably 15" speaker..to somehow avoid that 7th-string-ripping-the-speaker-apart-at-almost-max-volume..
Old 12-06-2006, 01:27 PM
Martinmax  is offline
Posts: 14  -  iTrader: (0)
hey i have a kb100 and i use for practise with my bend with vamp 2 so i have a hard hitting drummer and with volume at 4 i died him so get that peavey and dont worry
Old 12-07-2006, 04:54 PM
Tanx..but that peavey is not longer an option, unfortunately..but i will keep that in mind if it appears again in the adds..! nice to hear!
bass amp, death metal, flextone iii, power amp, seymour duncan, solid state amp, tube amp, tube head, tube power amp
Just picked up this amp: Yamaha/Soldano T50C 50 watt 1x12 Combo Superuser Gear and Equipment 12 06-15-2005 04:26 PM
F/T: Peavey Ultra 60 Watt 1x12 amp For...... Jackson Soloist Classified Ads: Guitars and Gear 0 02-13-2005 10:51 PM
100 Watt head as loud as 2*50 Watts poweramp LennyNero Gear and Equipment 11 12-01-2004 12:15 PM
Nice and cheap 50 watt combo!!! ScottB Gear and Equipment 7 06-10-2003 03:07 AM
Ultimate hard rock 40-60 watt 1x12 tube combo????? Polaris20 Gear and Equipment 15 02-28-2003 11:12 AM
