Originally Posted by Draco
I've read on several message boards (from people who seem to know what they're talking about) that for a TUBE amp, a safer mismatch is to plug into a lower rated cab (i.e. 16 ohm output of the amp into 8 ohm cab). For solid state, the safer mismatch would be how you explained it. I'm far from an expert in these matters, but I've read people explaining this on more than one occasion.
Those people are incorrect. It won't happen immediately, but the output transformer on the head will fry. It'll work, albeit badly, right up to the point of failure.
Running an 8-ohm cabinet off the 16-ohm tap in EITHER a tube or solid-state amp will fry the output transformer. The values on the taps are MINIMUMS. So, on the 16-ohm tap, you need a MINIMUM 16-ohm load. Last time I checked 8 < 16 .
If you want to be as absolutely safe as possible, run off the 4-ohm tap. Unless you have some weird 2-ohm cabinet (usually reserved for stereo equipment and such) you'll be safe.
Cheers,
Race
