the roadking has el34 and 6l6 powertubes
FEATURES
Handbuilt in the USA
Progressive Linkage™, Channel Assignable Power Amp (patent 5,559,469) featuring 4x6L6 & 2xEL34, which allows you to select either 2x6L6, 2xEL34, 2x6L6+2xEL34, 4x6L6
or 4x6L6+2xEL34 for Power Ratings of 50, 100 & 120 Watts! / 6x12AX7, 2x5U4
Fixed Bias for Consistent, Maintenance Free Performance
4 Fully Independent Channels with 12 Modes (Channel 1 =Clean, Fat or Tweed™, Channel 2 =Clean, Fat or Brit, Channels 3 & 4=Raw, Vintage High Gain or Modern High Gain)
Each Channel features Independent Gain, Bass, Mid, Treble, Presence, All-Tube Long
Spring Reverb, 5 Position Progressive Linkage Power Tube Select (choices listed above), Channel Assignable Dual Rectification (Diode
or Tube Tracking-Patent Pending), Speaker Output Select (Speaker Out A, B or A+B), FX Loop 1 and 2 Select (2-Series Loop On/Off Switches per Channel or Footswitch Assignable)
Output Level Control (over all channels when activated)
Footswitchable Solo Level
Control – Patent 6,724,897 (over all channels when activated)
Bold/Spongy “Variac”
Switch
Pentode/Triode Switch for EL34s
True “Hard” Bypass Switch that removes FX Loop, Output Level & Solo Level Controls from signal path
Slave Out w/Level Control
Fan Cooled
External Switching Jacks for Channels 1, 2, 3, 4, Solo, Reverb, Loop 1 & Loop 2
Button Footswitch (Channel 1, Channel 2, Channel 3, Channel 4, External Trigger,
Reverb, Loop 1, Loop 2 & Solo)
Slip Cover
Available as:
Head (Width 27-3/4 inches)
2x12 Combo • C90 Speakers • Casters (Width 28-1/2 inches)
Optional Custom Finishes: Please Visit our Custom Design Gallery
Dual Series Effects Loops, include Master Send Level. All Loop circuitry can be hard bypassed. Run separate processing for Channels 1 & 2 and 3 & 4 or run Delay in Loop1 and Chorus in Loop 2…the possibilities are endless.
Power Status LEDs keep you informed of your pre-assigned Power Tube and Rectifier combinations per channel. Other front panel LEDs show Channel and Loop status.
Channels
1 & 2
Channels
3 & 4
A La Mode… Each Channel offers 3 Mode choices. The two pairs of Channels (Rhythm 1 & 2 and Lead 3 & 4) are duplicated so you can use similar pre-amp sounds with different Power Tube, Rectifier and Wattage configurations. Channels 1 & 2 offer CLEAN, FAT & BRIT. Channels 3 & 4 provide RAW, VINTAGE & MODERN.
Cabinet Switcher, a unique Road King feature, includes load protection and let’s you dedicate specific cabs for clean and overdriven sounds. Also works great with our split-chamber Road King cabs which include separate open and closed sections
Built In Variac (patented) lets you further tune the power section to your style. Kick the A.C. voltage down for a looser, scoopier feel or hit Bold for maximum headroom and low-end tightness.
External Trigger Ports (Latching and Pulse) on amplifier rear allow remote control of FX, drum machines, samplers and more from the King’s footcontroller.
http://www.mesaboogie.com/Product_In...g/roadking.htm
