Originally Posted by losgatosrg350dx
why dont you just put the amp into a better combo cabinet, like a sealed or ported or whatever...use the speakers from the sound city cab or whatever....maybe turn your fender combo into a seal box cabinet....i dunno
seems more work than ever...
I'm not sure what you mean :/.
My issue is that I have a $650 dollar cabinet running a $200 Pod through a $100 crate head and I'd like to use the hot rod deluxe but in a head-format in the meantime until I save up for a "real"
amp head.
I know people that can do the work as far as taking the amp part out of the combo, and even build a new frame for it.
But I need know the specifics on what I have to do to make the 2nd output on the amp a 4
ohm output. The diagram in the manual helps some but it doesn't tell me what I should/shouldn't use.
Thanks!
