Old 07-07-2008, 05:48 PM
bringer of torture  is offline
Posts: 250  -  iTrader: (4)
Another Legacy question (MIDI switching?)
Actually two, heh.
1) Have any of you guys worked with the MIDI switching capability on the Legacy? Can I switch Legacy channels with the "switch out" on my G Major? The Legacy manual doesn't cover this and I couldn't find a concrete answer either way.
2)What kind of cable do I need?
I've already got a Rocktron Midi Mate and Ibanez Tube Screamer to step on; having the Legacy footswitch to worry about as well is just too much. Thanks in advance guys!
Old 07-07-2008, 06:18 PM
Re: Another Legacy question (MIDI switching?)
Aha, found it myself (From the John Petrucci board):
If your amp has a T/S (mono) or TRS (stereo) footswitch jack, it is highly likely that any latching relay switcher can change channels. All you need do is plug a standard instrument cable from a loop output on the GCX into this and you are in business.
On my Carvin Legacy head I found the channel switching was done on the ring/sleeve of the TRS jack, so I had to make a custom cable which was 10 minute job.
Old 07-07-2008, 06:26 PM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
I don't have a Legacy head but i'm familiar with the G-Major. If the Legacy uses a stereo cable-end for its footswitch, a stereo cable link from the G-Major to the Legacy should work. Connect + program the Midimate to the G-Major. Access Level All/Relay 1 + 2 to program the channel switching. If it works, Relay 1 changes clean to dirty and Relay 2 enables/disables the Reverb. If you only need to change the clean/dirty channel, i would assume connecting a mono cable from the G-Major to the Legacy head should do the trick.
a mono or stereo cable long enough to reach the head from the G-Major. According to the manual on the Carvin site:
"Most foot pedals with 2 switches, a stereo cord and plug will work... first the channel SELECT switch on the front panel must be selected to the "OUT" channel 1 position before the footswitch[channel switching] will work."
Reg
Old 07-07-2008, 06:32 PM
Thanks for the additional info, Reg, that's basically what I needed to know!
ibanez tube screamer, rocktron midi mate
midi switching controls johnboy30230 Gear and Equipment 0 05-08-2007 06:17 PM
Considering switching to racks / midi . SpikeSocietySucks Gear and Equipment 14 05-14-2006 03:32 PM
midi multiFX with amp switching relays, choices? Ki swordsman Gear and Equipment 4 05-04-2006 11:56 AM
Switching amp channels and midi presets with the same pedal kent k Gear and Equipment 11 06-17-2004 02:52 PM
HEL me out with MIDI switching device :) jpwannabe Gear and Equipment 8 03-14-2004 09:04 PM
