Old 04-18-2006, 02:01 PM
NTMAD8R22  is offline
Posts: 39  -  iTrader: (0)
Anyone use wall-mounted guitar hangers???
I'm getting kinda tired of having my guitars all over the place. i've been looking at these wall-mounted hangers (ie. hercules, string swing etc...) Anyone have experience with any of them, or like one more then the other.
PS, i've got an acoustic, strat, rg's and a carvin 7. I would ideally like the same one for each guitar.
Thanks in advance
Old 04-18-2006, 02:09 PM
mesamaster  is offline
Re: Anyone use wall-mounted guitar hangers???
Thanks in advance
i have them for 5 of my guitars, they are great. they dont put stress on the neck like a regular guitar stand - they look great and fit all types of guitars.
the hanger swivels to accomodate different headstocks
Old 04-18-2006, 02:11 PM
marcusc  is offline
Posts: 13  -  iTrader: (0)
I use Hercules and think they are great.
Old 04-18-2006, 02:29 PM
bduersch  is offline
Posts: 1,357  -  iTrader: (1)
Yeah, I use a couple of the Wallacher hangers, though not as they were intended to be used...
They seem sturdy enough, even though they only have one anchor. If I was going to hang heavier guitars, though, I'd probably look for something with two wall anchors.
--B
Old 04-18-2006, 03:10 PM
slash  is offline
Posts: 62  -  iTrader: (0)
Reviews: 8
sure do
Old 04-18-2006, 03:14 PM
bammbamm  is offline
I have 2 string swing and then I made this one from a chunk of oak I routed and stained and mounted at a 30 degree angle.
Both work fine, you just need to insure you mount the string swing on a wall stud, I wouldn't trust my guitars hanging on wall anchors that could pop out.
Bamm
Old 04-18-2006, 06:42 PM
EvilEmuOfDoom  is offline
Posts: 380  -  iTrader: (11)
Bamm
Actually, they're not bad with the drywall anchors they come with. In my old apartment I had two HM Strats, a RG550, and my classical all mounted using the drywall anchors because the building had aluminum studs. I was really skeptical at first but they were pretty sturdy. I first tested them with my hand and when that felt fine a I hung the classical for a week. Didn't loosen up at all so then I hung the others. They were up for 5 months without any problems.
So, basically, mount them to studs if you can. But if you can't for some reason the drywall anchors worked fine for me.
Allen
Old 04-18-2006, 06:47 PM
bpd111  is offline
Posts: 1,628  -  iTrader: (7)
+1 for string swing.
Old 04-18-2006, 06:48 PM
S-man  is offline
Posts: 1,757  -  iTrader: (0)
^^^Sounds scary to me. I'd at least want 2 toggle bolts. If 2 toggle bolts rip through the drywall, you got other problems. A stud is best.
BTW, you can screw into metal studs. You just need to use the right screws.
Old 04-18-2006, 07:24 PM
bluealien  is offline
Posts: 959  -  iTrader: (0)
I use hercules, they are great, with the swivel head and also the arms lock in front of the guitar when set in. however I did change out the dry wall screws & anchors that came with them, the new Spreading anchors I got hold 220lbs, I was able to pull the other s out of my wall putting force on the guitar hanger.
Old 04-18-2006, 08:17 PM
Yeah, I found out later that I could go into the metal studs but they were already hung and holding up fine. They were very snug up until the very second I pulled them out.
Old 04-18-2006, 08:31 PM
Wolfram  is offline
Posts: 911  -  iTrader: (0)
Reviews: 12
I also use Hercules wall hangers with the Auto Grab System. I think they are a little more expensive but lets face it, it's a big investment that they are securing! The model I chose is the GSP39WB, because it has a three screw mount. I have included close up pics so that you can see the three screws and also a picture of the anchors that I use. They have worked great going into the plaster board. I was worried that the plasterboard may not be able to actually hold the weight of the guitars but it is fine. I am thinking of putting up another two guitars below the three that I have up there at present. It is great seeing the pics of others guitar collections and where, how they set them up around the house.
Wolfram
Old 04-18-2006, 09:43 PM
Ant1981  is offline
Posts: 2,181  -  iTrader: (3)
Loving the PMC
Old 04-18-2006, 09:55 PM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
i drove around locally to find good hangers and went with these from ****** myself. the great part is they're angled and the pressure of the guitar LOCKS the neck in the hanger. you can also throw the strap over so it's kidproof.
i too didn't use the screws/anchors instead used T-bolts into a pine board that was directly mounted to wall studs. highly recommended... glen
Old 04-18-2006, 11:12 PM
Rotti  is offline
Posts: 3,341  -  iTrader: (8)
I use the Herc's too.
guitar collection, killer guitar
Why is Steve Vai's Prototype DNA in a guitar store window? - moochie777 JEM and Universe Guitars 21 06-04-2010 02:39 AM
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma JEM and Universe Guitars 89 06-18-2007 11:57 AM
FS: UK Guitar Mags jippy Classified Ads: Guitars and Gear 1 06-23-2005 11:12 AM
New Guitar...which one should it be? Ugoyin Other 6-string Guitars (non-Ibanez brand) 5 05-12-2003 10:19 PM
Known history of Guitar.. (lots of people have it wrong) - a vwall Archived Topics and Common Questions - GO HERE FIRST 20 12-30-2001 01:44 PM
