Gear and Equipment
Best Bedroom Level Practice Amp?
Gear and Equipment
06-03-2007, 01:37 PM
master_of_metal_puppets
Posts: 12 - iTrader: (
Here is what I want ...
1. an amp that sounds GREAT at bedroom levels; plus
2. LSC cleans; plus
3.
mark IIC
+ leads; plus
4. RKII crunch; plus
5. sells for under $200 (just kidding).
The crunch I can live without but what amp gets me closest to the first 3 on my list? MESA or any other manufacturer.
Help!
Thanks!
Find all posts by master_of_metal_puppets
06-03-2007, 02:58 PM
CityofBlindingLights
Posts: 563 - iTrader: (
Re: Best Bedroom Level Practice Amp?
I'm not sure about all your criteria, but the Ibanez TBX15R is a GREAT amp that can actually go louder than it seems it can, it's an awesome amp. I have a TB15R, and it's still cranking after six years of somewhat heavy abouse.
Find all posts by CityofBlindingLights
06-03-2007, 03:51 PM
Vinco
Posts: 234 - iTrader: (
Try Vox DA5 or DA15
Amp modelisation + onboard effect that all sound plain great at bedroom level!
I own a DA5 and I am still surprised by its possibilities!
Vinco
Find all posts by Vinco
06-03-2007, 04:51 PM
Dee
Posts: 8,514 - iTrader: (
Behringer V-Amp Pro through a semi-decent hifi.
Dee
Find all posts by Dee
06-03-2007, 04:57 PM
jemplayer55
Posts: 2,627 - iTrader: (
Why not get a modeling pedal and just plug in a good set of head phones?? It'll have all your tones plus effects and can be used later with an amp.
jemplayer55
Find all posts by jemplayer55
06-03-2007, 06:15 PM
yoyo1299
Posts: 637 - iTrader: (
/\ nah, i did that with my gt-8, but it sounds totally different plugged into an amp
yoyo1299
Find all posts by yoyo1299
06-03-2007, 06:49 PM
jemplayer55
yoyo1299
You have to tweak it to suite your amp. You could copy your customised patches and tweak them to work on your amp in a matter of minutes.
jemplayer55
06-03-2007, 09:25 PM
The headphone option is what I have now. I don't it for 2 reasons. F*cking around tied to headphones all the time and most importantly TONE. I want a nice warm tube tone, not some digital rendering of one.
I have a POD XT but distortion sucks on those. I DO however get a killer Mark IIC+
clean tone
on it.
What I may do is get a
tube power amp
and use the Pod as a preamp and run it all into an earcandy speaker. For distortion, stick a BB pedal in front (again for that tube sound).
Wondering if the power amp will warm up the Pod XT output and by how much.
Anybody?
06-03-2007, 09:51 PM
satchboogeyman
Posts: 358 - iTrader: (
Vinco
Try Vox DA5 or DA15
I second this lil' amp.
satchboogeyman
Find all posts by satchboogeyman
06-04-2007, 03:27 AM
Ki swordsman
Posts: 1,273 - iTrader: (
Kustom KLA 25R (it's an old model) and Kustom arrow16r, also called solo16r i think?
both awesome cheap practice amps with great shred solo tone, the KLA25r is the greatest cheap lil prac amp i've ever been able to find and hear in person. though there's a lot about that i wouldn't have had the pleasure to try. the solo16r has even more gain and is more modern(does practice metal very well). both amps have great generous amounts of bass and nice sounding gain(nicest=KLA25r)
Ki swordsman
Find all posts by Ki swordsman
06-04-2007, 04:00 AM
microdmitry
Posts: 1,687 - iTrader: (
If you want good tone at bedroom volume levels, you're out of luck. If you want somewhat decent tone - get a cheap Line 6 modeling amp. It sounds the same at low volume. You won't get a Mark IIC+ out of it, though. In order to get that you'll need a Mark IIC+, and crank the heck out of it to boot.
microdmitry
Find all posts by microdmitry
06-04-2007, 04:31 AM
mi2tom
Posts: 7,522 - iTrader: (
Get the line6 toneport.
mi2tom
Visit mi2tom's homepage!
Find all posts by mi2tom
06-04-2007, 04:52 AM
the.godfather
Posts: 3,593 - iTrader: (
If you want a bedroom
practice amp
, do not go for tubes at all. It's a waste of time at bedroom levels. So definitely go solidstate, and I'd say definitely go modelling too. So anything from Line 6, Behringer, Tech 21, Roland, would do the job very nicely.
The Behringer GMX series are great (which is what I own), as are the
Roland Cube
series by all accounts.
But as the others have said, you wont get Mark Mark IIC+ tone out a 1x12 solidstate modelling amp. So don't go expecting too much. Even with serious tweakage.
the.godfather
Find all posts by the.godfather
06-04-2007, 08:22 AM
dickieboy
Posts: 446 - iTrader: (
Vinco
Try Vox DA5 or DA15
satchboogeyman
i'll third the lil' VOX DA5.. i have one too.. it's well trick, and at bedroom levels its all you need.. i bought it for use with my Ovations but was amazed when i plugged my RG into it.. battery or mains, switchable 0.5 - 1.5 - 5 watts.. has a line in and a mic in should you fancy a sing-song..
and mine looks killer in camo..
£75 UKP.. ya can't go wrong!!
08:37 AM
dickieboy
Find all posts by dickieboy
06-04-2007, 12:58 PM
jazzedout
Posts: 671 - iTrader: (
IMHO, one good choice for nice tube sound at bedroom level is the Laney LC-15R. very nice clean tone, and bluesy overdrive (I changed the preamp tubes and that improved but still not a
high gain amp
). It doesn't have ultra high gain though. Nicest clean tone I get is cranking its volume to about 7-8 and the gain at 1. I have a little zoom multifx infront of it that I use for high gain. I also use the zoom to control the overall volume of the amp if I want to ise it at lower levels. I believe it doesn't change the tone as much as lowering the amps volume. Another plus is a rather nice and rich sounding Accutronics reverb unit.
jazzedout
Find all posts by jazzedout
clean tone
high gain amp
mark iic
peavey jsx
power amp
practice amp
preamp tube
roland cube
tube power amp
tube tone
how to level lo-pro edge
how to level frets
how to fret level
how to dress and level frets
how to level a high fret with standard tools
little practice amp
kent
Gear and Equipment
04:20 PM
Trem float level
Ant1981
Tech: Setup, Repairs and Mods
09:17 PM
How do you practice?
Azrael
Guitar Lessons & Music Theory
10:42 AM
Technique Building Practice Routine - here's mine
jem7vwh
12:01 AM
Bedroom amp suggestion
cowcowcow
Gear and Equipment
07:35 PM
11:18 PM
