Old 02-23-2003, 09:53 PM
BluewookieJim  is offline
Posts: 59  -  iTrader: (2)
Boss Noise Suppressor NS-2
Who here uses one of these things?
I just got one today, and I honestly don't know how I've managed all these years without one.
Ever since I bought my current house, I've always been telling people that it's just not enjoyable to play in my "rec room" becuase of all the noise and interference.
We'll that's not a problem anymore.
Anyway, what I wanted to know was how does everyone that has one set it up. I've seen some people put it after all there effects right before the amp, and then I've seen where others use it in a loop.
My current setup looks like this:
Guitar
v
Morley Bad Horsie 2
v
(Input Jack) Boss Noise Suppressor NS-2, then out of the (Send) jack
v
Digitech Tone Driver Overdrive
v
Digitech Main Squeeze Compression/Sustainer
v
(Return jack) Boss Noise Suppressor, then out out the (Output jack)
v
Digitech DigiDelay Digital Delay
v
(AMP) Fender Princeton Chorus
Old 02-24-2003, 04:55 AM
SalemB  is offline
Posts: 848  -  iTrader: (0)
Yep, got one of those.
Plugs my guitar into a crybaby that goes into the ns-2. Then there is 5 more pedals in the ns-2 loop before the signal is fed into my jazzchorus.
Old 03-14-2006, 04:51 AM
paulvai  is offline
Posts: 31  -  iTrader: (0)
Re: Boss Noise Suppressor NS-2
normally you are supposed to put it in after your distortion in order cut the noise, supossidly. Malmsteen Puts it in after firstly a guitar > overdrive> Octave pedal> NS-2> then other stuff like flanger and delay. Check out this web site: http://www.yngwie.org/Gear.htm
Old 03-14-2006, 04:39 PM
SalemB  is offline
Yngwie doesn't use the built-in effects loop. Using the loop, the dist will be both before and after the NS-2.
Old 03-15-2006, 07:26 AM
paulvai  is offline
o right.
fender princeton, fender princeton chorus, noise suppressor
