Old 01-30-2009, 01:47 AM
Kramerman  is offline
Posts: 45  -  iTrader: (0)
cable help
I have an ibanez S series with a ZR trem. recently I got a VOX amplug headphone amp. the problem is, since the S series has the jack on the front of the body instead of the side, it covers the trem. so, I'm unable to push down on it. is there such thing as a cable that I can plug into my guitar and plug the amp into the other end so I can use my trem?
Old 01-30-2009, 09:40 AM
hall  is offline
Posts: 129  -  iTrader: (0)
Re: cable help
Looking at this Amplug unit, you'll have to mount it "remote" and not directly into the jack. I don't know if they're readily available, but a short cable with a male 1/4" connector on one end and a female 1/4" connector on the other will solve this.
Guitar< <<--short-cable<<-- <<--Amplug
(input jack) (male-to-female 1/4" cable) (Amplug w/ 1/4" male)
Old 01-30-2009, 10:24 AM
rob777vdy  is offline
Posts: 2,575  -  iTrader: (3)
Images: 3
Re: cable help
planet wave cables.one end is like your standard shaped jack,whereas the other end is like a 7 shaped jack.i wouldnt think this wouldnt get in the way of your trem.hope this helps ya.
amplug ibanez s series
Speaker Cable VS Instrument Cable Lifeofsobriety Gear and Equipment 10 04-24-2008 03:05 PM
LightSnake 1/4" Guitar cable to USB cable.(Connects guitar to computer via USB) GuitarEvan07 Classified Ads: Guitars and Gear 0 11-24-2007 05:57 PM
Cable Arek Gear and Equipment 0 02-10-2007 02:06 AM
Where does this cable go? junebughunter Pickups & wiring 6 11-16-2005 07:58 PM
JS cable Flakman JS (Satriani Model) Ibanez Guitars 6 08-17-2003 05:24 PM
