Gear and Equipment
cable tricks - hmmm im stuck here
Gear and Equipment
09-20-2001, 07:04 AM
one less than none
Posts: 376 - iTrader: (
there is a trick i believe invloving balanced to unbalanced cable runs that involves inserting a 100M ohm resistor into the scheme to remove hum
i was just wondering what rating resistor to use, looking on rs i can get them between 0125 - 0.6W
i was wondering if anyone knew (i thought the sound engineer in particular might)
one less than none
Visit one less than none's homepage!
Find all posts by one less than none
09-20-2001, 08:11 AM
Jesse Greenawalt
Posts: 39 - iTrader: (
cable tricks
100 ohms should work, wattage shouldn't matter much - wire it in series with the sheild...
Jesse Greenawalt
Find all posts by Jesse Greenawalt
09-20-2001, 09:02 AM
one less than none
cable tricks
hmmm im a bit new to this kinda 'tomfollery' - i thought 100M was 100 ohms ?
whenever i have lokked at resitors they tend to have R or K as a surfix
I am getting a bit confused by it all
which one do i want ?
one less than none
09-20-2001, 01:01 PM
7 Dying Trees
Posts: 1,708 - iTrader: (
cable tricks
Quick Explanation:
100R = 100ohms (actually, doesn't have the R as suffix i don't think)
100K = 100Kilo-ohms = 100000 ohms
100M = 100000K = 100000000ohms
well, you get the idea...
(Edited by 7 Dying Trees at 12:02 pm on Sep. 20, 2001)
7 Dying Trees
Find all posts by 7 Dying Trees
09-20-2001, 03:07 PM
one less than none
cable tricks
hey hey
thank you Mr Trees
Now i can get stuff sorted :biggrin:
(Edited by one less than none at 2:09 pm on Sep. 20, 2001)
one less than none
video of how to play eugene's tricks bag
how to tighten a stuck screw
volume pot is stuck
a piece of my whammy bar got stuck in its whole what do i do?
how thick is a cab cable?
06:05 PM
