Old 11-08-2006, 07:32 PM
Silverburst  is offline
Posts: 488  -  iTrader: (1)
Carvin Legacy EL34/6L6 and preamp tubes
Hi Legacy (ex)players. Anyone tried 6L6's in these tanks ? What brand and how did they compare to the stock EL34 (mine has Sovteks) ? Same for the preamp tubes of you use different brands (mine has Groove Tubes, stock if I'm correct) I'd love to hear your experiences. Thx
Mike
Old 11-08-2006, 10:21 PM
rummy  is offline
Posts: 99  -  iTrader: (0)
Re: Carvin Legacy EL34/6L6 and preamp tubes
JJs.
www.eurotubes.com
Old 11-09-2006, 01:03 AM
goodwill559  is offline
Posts: 42  -  iTrader: (2)
Power Tubes:
First i tried Ruby Tubes EL34B-STR (Shuguang EL34-B). They sounded better than the stock Sovteks. Very good sound, hard to describe but they sounded bigger, not louder or heavier, but more wide open.
Then i tried JJ / Tesla 6L6GC and i immediately liked them over EL34's. After that i tried TAD 6L6GC-STR and that was the end of my search. Good raunchy sound.
Preamp Tubes:
Tried the new TungSol, and compared to the stock Groove Tubes, they had a brighter sound, a hair less gain. Then tried JJ 803s (long plate). Great sounding midrange, not as much gain. Next was high gain JJ ECC83 and ended up keeping two high gain JJ ECC83's in V1&V2.
Different strokes for different folks.
Old 11-09-2006, 06:28 AM
Indeed a great site Rummy, I'm gonna check it out more closely.
Thx for sharing your findings goodwill559, exactly what I'm looking for. I would like the lead channel a bit more scooped and tighter, and a tad more gain would be great as well. Did the high gain JJ ECC83 pushed your Legacy in that direction besides the higher gain ?
Of course all this is very subjective, but you gotta start somewhere
Old 11-09-2006, 04:43 PM
I didn't think that the Groove Tubes and JJ ECC83 were all that different sounding from each other apart from the high gain ECC83 having more gain and a bit darker sounding. They both had a tighter sound than the new TungSol 12AX7, but the TungSol had more high end. Bob at Eurotubes can get you high gain JJ's.
The biggest difference to my ears was the power tube switch from EL34 to 6L6. That gave a more scooped sound, with more on top and on the bottom whereas the EL34 had a nice bloom in the midrange, a more well behaved, even and graceful sound.
I give the most weight to the power tube switch getting you closer to your goal and then would say preamp tubes will help you fine tune your sound from there.
groove tubes, preamp tube
A guide to choosing tubes and cabinets! power freak Gear and Equipment 78 09-18-2011 11:35 PM
Switching between legacy and preamp EL-CeeDee Gear and Equipment 30 09-01-2007 05:43 AM
More preamp tubes = more gain? AirGuitarHero Gear and Equipment 7 06-26-2005 03:00 PM
Marshall DSL 100 -- Tone problem = Preamp Tubes? JohnnyRasgueado Gear and Equipment 4 05-21-2004 09:01 PM
Can these preamp tubes be used for my Marshall amp??? - It's firegarden Tech: Setup, Repairs and Mods 2 12-17-2001 11:57 AM
