Old 01-25-2007, 11:51 PM
GlassCasket  is offline
Posts: 65  -  iTrader: (1)
Connecting a Rack please help!
My friend jsut bought a rack setup and we ar enot completely sure how to hook it all up he consists of
Peavey 60 classic poweramp
Engl E530 pre
BBE Maxcon
and a TC Electronics G sharp
now i can hook up so all but the g sharp work pleasepost any seggestions or diagrams that will help, the TC book is **** i looked already for hours saw some but none for a stright rack
also the power amp sounds kinda weak i was thinking replace fuse first then see if new tubes are needed? please help
thanks
Old 01-26-2007, 12:02 AM
elcid  is online
Posts: 8,719  -  iTrader: (12)
Re: Connecting a Rack please help!
It's not a fuse issue, if it was the amp wouldn't power up.
I dont know anything about the engle, are you going through the effects loop with the G sharp or directly into the from of the amp?
If you are going through the loop are you using both the send and return? Are you sure those are hooked up right?
Old 01-26-2007, 12:17 AM
Kontalonis  is offline
Posts: 1,006  -  iTrader: (3)
Basically it should go like this in a rack (mounting included):
From BOTTOM to TOP:
Peavey Classic 60 Out to Cab
Engl Pre Out to Power Amp
G Sharp out to Engl
Guitar in to G sharp
(All outs go to next items in)
*Maxcom running through FX Loop of Engl*
I'm no rack nut but i think this is correct, as for the power amp check your tubes glow. Make sure they are all pressed in good (be easy!) and ALWAYS make sure there is a fully functional cab with matching impedence hooked up. Not sure how experienced you are with tube amps so just letting you know...
If you stack the items like i have them (from bottom to top) and take a picture from the back i can draw lines in paint as to where the coords go.
Old 01-26-2007, 12:47 AM
Here i went ahead and made a little diagram. Yellow end to yellow end is where the coords connect. Hope you get this figured out. If any other jemsiter sees an error please help us out cause like i said i'm no rack nut...
*Remember to plug your guitar into the front of the G-Sharp and NOT the ENGL!*
Old 01-27-2007, 11:15 PM
hirah  is offline
Posts: 135  -  iTrader: (4)
Reviews: 3
i would go line outs from the engl to the g sharp inputs.
line outs of the gsharp to the bbe inputs.
bbe outputs to the 60/60 inputs.
60/60 speaker outs to the cabs.
remember, you need to hook up both sides of the poweramp
if you have the stereo 60/60. if you have the mono 60, nevermind.
the delays and reverbs will be better in the loop, as i don't think the gsharp likes to see an input from a guitar.
Old 01-28-2007, 12:56 AM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
While I can appreciate that you want to help, if you're not sure about the advice your giving, not give the advice. Bad advice is not good. Your diagram is very neat but it's also very wrong I'm sorry to say but I'll give you an A+ for effort.
Seriously thought, don't plug into the G Sharp first then into the Engl. It will sound bad because reverb or delay sounds bad in front of distortion.
Connecting up this rig is pretty simple. Hirah's advice is spot on.
BTW GlassCasket, spending a little time reading about how a signal path works for a guitar rig would behoove you. If you understood that, you'd be able to wire up any guitar rack you can imagine. There are few basic rules to follow but it ain't rocket science.
Old 01-28-2007, 01:24 AM
Thanks for the GOOD advice. I guess i don't know rack equipment as good as i thought. Cheers mate!
Old 01-28-2007, 11:57 PM
i dotn ahve an input ont he front of the G Sharp....
Old 01-29-2007, 08:20 AM
toneboy  is offline
Originally Posted by GlassCasket View Post
i dont have an input on the front of the G Sharp....
Nor do you need one. Plug the guitar into your preamp in the front and everything else is connected in the rear of the rack.
Old 02-10-2007, 03:49 AM
adedeathmetal  is offline
Posts: 8  -  iTrader: (0)
That would be my Rack, Thanks for all the help finally got it working good. For a picture of it go here
http://i139.photobucket.com/albums/q...32287-0001.jpg
peavey classic, power amp, rack setup, tube amp, tube amps
Rack Connecting GlassCasket Gear and Equipment 15 11-11-2006 03:14 AM
Connecting Rack Preamps teof Gear and Equipment 3 01-17-2005 01:58 PM
Can some genius help me? Question on connecting rack gear corganrocks Gear and Equipment 1 11-02-2004 07:14 PM
Rack Effects: what are the basics? Frankie Gear and Equipment 5 06-09-2002 12:30 AM
