Old 01-16-2005, 01:11 PM
teof  is offline
Posts: 186  -  iTrader: (9)
Connecting Rack Preamps
Hi guys,
I was thinking of rack preamps like marshall jmp-1. How do you guys actually connect them? Is it really a must to connect it to a regular amp? Thanks.
Old 01-16-2005, 01:45 PM
pawel  is offline
Posts: 2,656  -  iTrader: (3)
Re: Connecting Rack Preamps
Effects-in of an amp, or a power amp would be advised. I don't know if you can get any good results running these dorect into a PA...
Old 01-17-2005, 10:47 AM
bammbamm  is offline
Red face
Typically for guitar you setup your preamp as the front end of your amplifier.
Imagine you're breaking apart your amp head into 2 componants, preamp and power amp. Place the preamp at the front of your signal chain and then power amp at the rear into the speakers.
Between them is the effects loop, this is where you place the majority of your effects after the tone shaping circuits but before your output to the power section. There are a few exceptions to the rules of course, such as placing things like wahs or flangers etc in front of the preamp to change the effect they have on the sound. Typically you will get a throatier sound from a flanger at the front of the chain.
http://www.Guitargeek.com has some GREAT examples of rig setups of the pros.
This may help you out considerably.
Good luck,
Bammbamm
Old 01-17-2005, 01:58 PM
jemke  is offline
Posts: 318  -  iTrader: (0)
you can use it like a 'stomp'box disto pedal in front of any clean sounding amp. But it sounds better with a power amp (because a regular guitar amp already has a preamp and could color the sound of the MP1). Just my experience
amp head, marshall jmp, power amp, rack pre
Can some genius help me? Question on connecting rack gear corganrocks Gear and Equipment 1 11-02-2004 07:14 PM
Rack Effects: what are the basics? Frankie Gear and Equipment 5 06-09-2002 12:30 AM
Rack tuner - can I put a tuner in the effects loop? - I coul djrjems Gear and Equipment 5 02-13-2002 10:55 PM
