Old 04-10-2008, 12:22 PM
shepard0620  is offline
Posts: 30  -  iTrader: (0)
Question
Correct Floyd Nut size for my RG?
Due to the unavailability of a left-handed, gold Edge I will be installing an OFR into my 550LM. Custom Vine is being finished and i have received the statement below in regards to the correct nut size for the neck. Can anyone assist me in determining which Floyd (R2, R3, R4.....) nut will fit?
"the nut should be 43mm wide. The fretboard will be 16" radius, and the
string spacing should be standard Fender spacing (please check the floyd
spacing match to normal Fender). That should be it really, just make sure you
grab a couple of shims in case you need to adjust up a little."
A Floyd rep informed me of getting an R2 but that was 1 5/8" and I thought 43mm would be R3-R4 range??? Please end my suffering!
Much Thanks
Old 04-10-2008, 02:18 PM
gu1tar  is offline
Posts: 858  -  iTrader: (0)
Re: Correct Floyd Nut size for my RG?
First of all, if you are a lefty, you want the L, not the R nut.
If it's 43mm wide at the nut, that is 1-11/16" so the R2 at 1-5/8 is not what you want.
http://www.floydrose.com/nutsizes.html
Even with a 16" radius fingerboard, I'm guessing that the nut is actually a 10" radius since that's the most popular Floyd nut, but I'm not sure. Otherwise you will probably need nuts #8 or 10 as they are 15" radius.
So you are either going to need a L4, L8, or L10.
Your best bet is probably to email floyd rose support and ask them.
techsupport@floydrose.com
Old 04-10-2008, 02:36 PM
I emailed Floyd but they have not replied as of yet.
I appreciate your time. I guess you can see the problem I'm having. Hopefully Floyd will respond and have the answer.
Thanks Gu1tar!
floyd rose
What is the correct angle for a floyd rose trem? big h Tech: Setup, Repairs and Mods 9 04-24-2003 03:55 AM
Floyd Rose Question MichaelQ Tech: Setup, Repairs and Mods 5 12-30-2002 02:32 PM
RG VS. VB * - please help me guys ChrisReedSmith Other Ibanez Guitars (including Premiums) 2 02-14-2002 06:18 PM
Which RG is my guitar - I got a used rg and am unsure as to slinger75 Other Ibanez Guitars (including Premiums) 16 01-23-2002 04:30 PM
Ibanez RG with hardtail? - high quality RG with no trem?? shask Other Ibanez Guitars (including Premiums) 11 04-09-2001 11:16 PM
