Old 08-03-2005, 05:52 PM
carlos grijalva  is offline
Posts: 1,183  -  iTrader: (0)
Crybaby 535Q help!!
Ther is a problem with my crybaby. Everytime i turn it on the pedal doesn't seem to work. I mean i don-t think its the battery, but evert time i step on it it doesn't do the effect. Can anyone help me?
Old 08-03-2005, 10:14 PM
Re: Crybaby 535Q help!!
yeah can anyone help i am a little nervous to think its borken or something
Old 08-03-2005, 10:22 PM
giannifive  is offline
Posts: 484  -  iTrader: (8)
Sounds like the battery to me. Did you jiggle the wires that connect to the battery? Also, have you tried pushing the on/off switch by hand several million times in a row? I actually had the massively industrial switch break on my Crybaby. Shocking, I know!
Old 08-03-2005, 11:13 PM
damo7v  is offline
Posts: 1,150  -  iTrader: (10)
another problem i've had with several Crybaby's is that the plastic cog that actuates the wah can come loose from the shaft of the pot.
you might want to check that.
Old 08-03-2005, 11:22 PM
well it wasn't the cog. it was the bettery! i the cable were loose. I put the AC adaptor and it worked perfectly. But thanks anyways.
Old 08-03-2005, 11:59 PM
De nada
FS: Crybaby 535Q wah, Nobels MS4 MIDI switcher, Morley ABY switch bduersch Classified Ads: Guitars and Gear 1 07-13-2005 02:54 PM
HELP!! Crybaby Multi-Wah 535Q ZeroDrift Tech: Setup, Repairs and Mods 2 07-11-2005 11:47 AM
Do-it-yourself DS1 or Crybaby mods? Petie Gear and Equipment 4 08-11-2003 02:53 AM
Switchless 535Q Wah - Anybody seen one? bduersch Gear and Equipment 9 02-25-2002 12:31 PM
