Gear and Equipment
Crybaby 535q -problem with range selector
Gear and Equipment
07-29-2007, 12:14 PM
Gawrilovic
Posts: 8 - iTrader: (
hi
I got a problem with my crybaby 535q.The range selector seems to work only
from third position (counting from high to low range-clockwise).First and
second positions doesn't affect sound in any way.I've had take off the upper foot
part because the flat spring needed some grease to stop squeacking and I also
had to open the body because the screw nut fell into it.Maybe something
happened during this operations...
Please pleaaase help !
Thank you in advance
Paul
Gawrilovic
Find all posts by Gawrilovic
07-29-2007, 12:38 PM
Salamander In The Sun
Posts: 859 - iTrader: (
Re: Crybaby 535q -problem with range selector
Open up your Crybaby and see if you maybe shook any connections loose, or something like that.
Find all posts by Salamander In The Sun
07-29-2007, 02:08 PM
Gawrilovic
I checked all connections leading from range selector to a main board and all seems to look fine...my first thought was that the
"frequency wheel" is responsible because it's not set in default position i'll try to do something with it.
Gawrilovic
07-29-2007, 02:21 PM
I searched the internet and can't seem to find anything about that particular part going out. You must have gotten a lemon.
I'd contact Dunlop to see if they'll fix it or replace it. I just wouldn't mention that I had taken it apart.
07-29-2007, 02:28 PM
Gawrilovic
I've already asked dunlop about this and they didn't reply so far...maybe on monday.
Gawrilovic
07-29-2007, 02:29 PM
Gawrilovic
Yeah, they're probably not there on Sunday's.
Like I said though, I wouldn't even bring up the fact that I had taken it apart.
07-29-2007, 02:49 PM
Gawrilovic
There is no posibliity of sending my crybaby to a service point...there is not any in europe not mentioning poland and shipping to USA would be risky and expensive.So I asked dunlop only for advice
I checked the wheel and it was set at wrong position(too much low frequency range) but this got nothing to do with the problem.
There is no change in frequency beetwen first second and third range... :/
Gawrilovic
07-29-2007, 02:53 PM
Gawrilovic
Oh, I never even thought about that.
I can't imagine what it could be, but Dunlop advertise 1,000,000+ stomps as the average Crybaby's life span.
I'm stumped, but best of luck with it.
07-29-2007, 03:17 PM
Gawrilovic
Yeeeaaah...last hope is a kindness of dunlop support center or maybe some handyman in my area.This malfunction is propably my fault...I think dunlop deserve it's fame.It still sounds great the only problem is that the possibilities are smaller.Thank you for your efforts
Gawrilovic
07-29-2007, 04:07 PM
chris101
Posts: 529 - iTrader: (
Check out
www.pedalmods.com
in the UK, they can probably fix it - might be expensive to send from poland though.
chris101
Find all posts by chris101
07-29-2007, 04:19 PM
Smitty
Posts: 841 - iTrader: (
Maybe you just don't hear the difference? I have a 535q and the tone selections aren't worlds apart...and the two you're talking about are very similar anyways, so yeah maybe you just aren't hearing it. As long as you get a good wah tone, don't worry about it.
smitty
Smitty
Visit Smitty's homepage!
Find all posts by Smitty
07-29-2007, 04:50 PM
Gawrilovic
You may be right Smitty I've taken it under my concern but as I remember my previous impressions (before malfunction) there was an audible change of pitch whenever you've changed the range.In my case it's audible only from about third position.Hmm I spent about an hour in order to check it and there is still no difference in sound at all (especially first and second)...
Gawrilovic
07-29-2007, 06:12 PM
Gawrilovic
Smitty
smitty
Yes you're right this is an essential issue as I played my crybaby during last two hours I've come to a conclusion that I'm fully satisfied. I'll try different copy at next ocassion who knows maybe I'm paranoic
Gawrilovic
07-29-2007, 09:52 PM
Smitty
Gawrilovic
Well thar ya go!
smitty
Smitty
how to fix the Dunlop 535Q Wah buzz
what is pu selector switch
how to wire an on-on selector switch
problem frequencies when mixing
ibanez 2010 range?
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault
leonard deroma
06-18-2007
11:57 AM
Crybaby 535Q help!!
carlos grijalva
Gear and Equipment
11:59 PM
FS: Crybaby 535Q wah, Nobels MS4 MIDI switcher, Morley ABY switch
bduersch
02:54 PM
JCM2000 DSL100 volume swell problem
Joshka
Gear and Equipment
40
04-14-2004
06:49 AM
04:26 AM
