Old 09-23-2007, 12:42 PM
casper777  is offline
Posts: 331  -  iTrader: (1)
Damage Control Solid Metal sound clip
Here it is for those you wnat to hear this great piece of gear!!
Just click on the image... Sound is quite accurate on this video, even if live there is much mure dynamics...
After the "solo", I engaged the "nuclear" boost... with max drive...
http://s180.photobucket.com/albums/x...t=MVI_1474.flv
Old 09-23-2007, 06:01 PM
yoyo1299  is offline
Posts: 637  -  iTrader: (0)
Re: Damage Control Solid Metal sound clip
nice!! liked that.... now what piece were u playing?
Old 09-24-2007, 03:44 AM
Thanks.. I was just improvising....
Old 09-24-2007, 02:07 PM
Entropy  is offline
Posts: 231  -  iTrader: (1)
Nice! Liked the heavy riffage at the end. Clear on the higher strings too.
Was pedal used for the "solo" also? or just after with nuclear.
Clean settings on your amp?
Old 09-25-2007, 04:29 AM
Thanks
Yes the pedal was engaged during the solo without the nuclear boost.
Max drive, bass at 2 o'clock, highs at noon and scoop at 11 o clock...
It's plugged in the clean channel of my Hughes & Kettner 20W Tube Edition, with neutral settings....
I can post other samples if you want
I can really achieve some great metal and Petrucci tones with it! mmmmh!!
higher strings
Show me the metal! HSH RG270 EMG pickup advice. kamix Pickups & wiring 1 07-07-2004 01:57 AM
Mesa Nomad 45 2x12: thoughts and sound clip Drew Gear and Equipment 16 06-07-2004 05:29 PM
MP-1 3.666 mod sound clip RobV Gear and Equipment 0 02-03-2004 11:15 AM
Help choosing metal distortion to use with solid state PA - gu1t4r Gear and Equipment 3 03-27-2002 11:56 PM
I FOUND MY SOUND!!! - And i wanna share it with you! armindo__dias Gear and Equipment 7 06-01-2001 12:32 AM
