Gear and Equipment
Death metal using Soldano Hot Rod 50+ any thoughts?
Gear and Equipment
09-02-2010, 10:36 AM
yxmmm
Posts: 9 - iTrader: (
Not familiar with Soldano. The only thing I know about is the SLO100 which is also a bank breaker...I might have found a pretty good deal on a used HR50+ just not sure can this thing do
heavey metal
Any comments are welcome
Thanks guys
yxmmm
Find all posts by yxmmm
09-02-2010, 02:01 PM
jono
Posts: 5,005 - iTrader: (
Re: Death metal using Soldano Hot Rod 50+ any thoughts?
If you can't make a Hot Rod do metal, you're using it wrong
A lot of guys tend to use a boost pedal either distortion or overdrive with the Hot Rods, not to add more gain so much as to tighten up the low end to a more "metal" tone.
jono
Find all posts by jono
09-02-2010, 03:13 PM
bancika
Posts: 555 - iTrader: (
It should have enough gain. I'd try putting graphic EQ in the loop for more control
bancika
Visit bancika's homepage!
Find all posts by bancika
09-02-2010, 05:02 PM
lynchfan6
Posts: 194 - iTrader: (
I had an HR-50+ ,,,now I'm a SLO player,,,and I'd recommend a Soldano to anyone for any kind of music. You could use a good clean boost to hit the front end a bit more if you want extreme gain.....worst case scenario...you'll be a death metal guitarist with amazing, harmonic rich, 3D tone!
lynchfan6
Find all posts by lynchfan6
09-03-2010, 02:25 PM
yxmmm
Thanks for the response guys. I appreciate that.
I'm more into tight, musical distorted rhythm tone. Just not sure whether the HR50 can handle that kinda gain without a stomp pedal.
BTW has anyone around here used both VHT Pittbull 50cl and Soldano HR50? How do you compare them, gain-wisely?
yxmmm
09-04-2010, 06:42 PM
Van Noord
Posts: 157 - iTrader: (
Reviews: 12
yxmmm
The Soldano won't do the level of gain you want without a boost pedal. With the Avenger I had, if the gain was past 6 it got very cloudy and and loose sounding.
Otherwise, when boosted it sounded great.
Here's a clip.
My amp's settings are shown along with the boost pedal and it's settings.
http://www.youtube.com/user/Van02028.../2/vuK3UeMOe9E
Van Noord
Find all posts by Van Noord
09-04-2010, 07:49 PM
yxmmm
[quote=Van Noord;1034001]The Soldano won't do the level of gain you want without a boost pedal. With the Avenger I had, if the gain was past 6 it got very cloudy and and loose sounding.
Here's a clip.
That sounds fantastic dude! I really love your tone.
I'm not sure how a Avenger compared to a HR50 though...
yxmmm
09-05-2010, 11:44 AM
Van Noord
Reviews: 12
I believe the HR50 is very similar to the Avenger. The only difference is the HR is two channel and has an effects loop.
Van Noord
09-10-2010, 01:37 PM
nickcoumbe
Posts: 2,417 - iTrader: (
Reviews: 34
^^^^^not sure if the hot rod is 2 channel. I though it was only one.
The Hot Rod is the only amp I have ever played that makes me sound good no matter what I play.
You need this amp in your life.
nickcoumbe
Visit nickcoumbe's homepage!
Find all posts by nickcoumbe
heavey metal
soldano hr50+
metal drum beat drum kit from hell
are metal guitar picks good for a guitar
how can u tell if your fender strat is an hm heavy metal strat
ibanez super tube vs super metal
Death Metal
Magical Muffin
Polls
59
07-21-2011
03:16 PM
Death metal fans?
IBNZ_RG
Players, Bands, People, Music & Tours
11:06 AM
DOD Death Metal FX86
primerib
06:35 PM
What is your opinion of death metal?
C.Thep
131
11-18-2006
11:49 PM
Death Metal Picking
Jeff
Guitar Lessons & Music Theory
02:07 AM
03:23 PM
