Briefly,
Class A has all the waveform going to each of the tubes, in fact, often there is only one tube.
Class B has opposite halves of the waveform going to each of the tubes, positive to one, negative to the other.
Class AB is somewhere in between with all the positive and a bit of the negative going to one tube and all the negative and a bit of the positive going to the other.
Many people think the VOX AC30 is class A, but it's really AB, although biased towards A, but if you turn it down it will operate as Class A.
http://www.duncanamps.com/technical/...of%20Operation
for further info
Jim
